Forum Header
[Bug Report] Crash using Mach3 imported configuration
- marcorighi
10 Nov 2016 01:40 - 10 Nov 2016 08:36 #82633
by marcorighi
[Bug Report] Crash using Mach3 imported configuration was created by marcorighi
Package: linuxcnc
Version: 1:2.7.7
Severity: normal
--- System information. ---
Architecture: i386
Kernel: Linux 3.4-9-rtai-686-pae
Debian Release: 7.11
500 oldstable-updates http.debian.net 500 oldstable
security.debian.org 500 oldstable http.debian.net 500 linuxcnc
linuxcnc.org
--- Package information. ---
Depends (Version) | Installed
libart-2.0-2 (>= 2.3.17) | 2.3.21-2
libatk1.0-0 (>= 1.12.4) | 2.4.0-2
libboost-python1.49.0 (>= 1.49.0-1) | 1.49.0-3.2
libc6 (>= 2.7) | 2.13-38+deb7u11
libcairo2 (>= 1.2.4) | 1.12.2-3+deb7u1
libfontconfig1 (>= 2.9.0) | 2.9.0-7.1+deb7u1
libfreetype6 (>= 2.2.1) | 2.4.9-1.1+deb7u3
libgcc1 (>= 1:4.1.1) | 1:4.7.2-5
libgdk-pixbuf2.0-0 (>= 2.22.0) | 2.26.1-1+deb7u5
libgl1-mesa-glx | 8.0.5-4+deb7u2
OR libgl1 | libglib2.0-0
(>= 2.12.0) |
2.33.12+really2.32.4-5
libglu1-mesa | 8.0.5-4+deb7u2 OR
libglu1 |
libgnomecanvas2-0 (>= 2.11.1) | 2.30.3-1.2
libgnomeprint2.2-0 (>= 2.17.0) | 2.18.8-3
libgnomeprintui2.2-0 (>= 2.17.0) | 2.18.6-3
libgtk2.0-0 (>= 2.8.0) | 2.24.10-2
libice6 (>= 1:1.0.0) | 2:1.0.8-2
libmodbus5 (>= 3.0.2) | 3.0.3-1
libncurses5 (>= 5.0) | 5.9-10
libpango1.0-0 (>= 1.14.0) | 1.30.0-1
libpython2.7 (>= 2.7) | 2.7.3-6+deb7u3
libreadline5 (>= 5.2) | 5.2+dfsg-2~deb7u1
libsm6 | 2:1.2.1-2
libstdc++6 (>= 4.6) | 4.7.2-5
libtinfo5 | 5.9-10
libusb-1.0-0 (>= 2:1.0.8) | 2:1.0.11-1
libx11-6 | 2:1.5.0-1+deb7u3
libxaw7 | 2:1.0.10-2
libxext6 | 2:1.3.1-2+deb7u1
libxft2 (>> 2.1.1) | 2.3.1-1
libxinerama1 | 2:1.1.2-1+deb7u1
libxml2 (>= 2.6.27) |
2.8.0+dfsg1-7+wheezy7 libxmu6
| 2:1.1.1-1 libxss1 |
1:1.2.2-1 libxt6 |
1:1.1.3-1+deb7u1 tk8.5 (>= 8.5.0) |
8.5.11-2 zlib1g (>= 1:1.1.4) |
1:1.2.7.dfsg-13 linux-image-3.4-9-rtai-686-pae |
3.4.55-4linuxcnc rtai-modules-3.4-9-rtai-686-pae |
3.9.265.gd99c55e OR rtai-modules-3.4-9 |
tcl8.5 | 8.5.11-2
bwidget (>= 1.7) | 1.9.5-1
libtk-img (>= 1.13) | 1:1.3-release-12
python (>= 2.7) | 2.7.3-4+deb7u1
python (<< 2.8) | 2.7.3-4+deb7u1
python-support (>= 0.90.0) | 1.0.15
python2.7-tk 2
Version: 1:2.7.7
Severity: normal
--- Please enter the report below this line. ---
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.7
Machine configuration directory is
'/media/data/users/home/marco/linuxcnc/configs/Mach3Mill' Machine
configuration file is 'Mach3Mill.ini'
INIFILE=/media/data/users/home/marco/linuxcnc/configs/Mach3Mill/Mach3Mill.ini
PARAMETER_FILE=linuxcnc.var TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mach3Mill.hal
Killing task linuxcncsvr, PID=6238
Debug file information:
sim_hardware.hal:30: parameter or pin
'parport.0.pin-02-out-invert-fake' not found 6238
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian
3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP
PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] Disabled fast string
operations [ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000
(reserved) [ 0.000000] BIOS-e820: 00000000000e0000 -
0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000
- 000000003ffd0000 (usable) [ 0.000000] BIOS-e820: 000000003ffd0000
- 000000003fff0c00 (reserved) [ 0.000000] BIOS-e820:
000000003fff0c00 - 000000003fffc000 (ACPI NVS) [ 0.000000]
BIOS-e820: 000000003fffc000 - 0000000040000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: Hewlett-Packard
Compaq nx7010 (DU394T#ABZ) /0860, BIOS 68BAL Ver. F.55 07/14/2005
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000
(usable) ==> (reserved) [ 0.000000] e820 remove range:
00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn =
0x3ffd0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type:
uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000]
00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CDFFF write-protect [ 0.000000] CE000-EFFFF
uncachable [ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem
0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 3652c000 - 3728e000
[ 0.000000] ACPI: RSDP 000f6560 00014 (v00 COMPAQ)
[ 0.000000] ACPI: RSDT 3fff0c84 00028 (v01 HP CPQ0860 14070520
CPQ 00000001) [ 0.000000] ACPI: FACP 3fff0c00 00084 (v02 HP
CPQ0860 00000002 CPQ 00000001) [ 0.000000] ACPI: DSDT 3fff0cac
04F8C (v01 HP nx7000 00010000 MSFT 0100000E) [ 0.000000] ACPI:
FACS 3fffbe80 00040 [ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003ffd0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003ffd0
[ 0.000000] On node 0 totalpages: 261983
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00,
node_mem_map f5d2c200 [ 0.000000] DMA zone: 32 pages used for
memmap [ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 272 pages used for memmap
[ 0.000000] HighMem zone: 34498 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- reenabling.
[ 0.000000] Found and enabled local APIC!
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 000000000009f000 -
00000000000a0000 [ 0.000000] PM: Registered nosave memory:
00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered
nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000]
Allocating PCI resources starting at 40000000 (gap: 40000000:c0000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1
nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77e5000
s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248
u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000]
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
259935 [ 0.000000] Kernel command line:
BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae
root=UUID=ca45ff4c-7174-42c4-901c-5d1f77b933f6 ro
initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000]
PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000]
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144
bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated
2096640 bytes of page_cgroup [ 0.000000] please try
'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003ffd0)
[ 0.000000] Memory: 1017228k/1048384k available (3495k kernel code,
30704k reserved, 1237k data, 416k init, 139080k highmem) [ 0.000000]
virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 -
0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 -
0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 -
0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 -
0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 -
0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a -
0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 -
0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor
honours the WP bit even in supervisor mode...Ok. [ 0.000000]
Preemptible hierarchical RCU implementation. [ 0.000000] RCU
dyntick-idle grace-period acceleration is enabled. [ 0.000000]
NR_IRQS:2304 nr_irqs:256 16 [ 0.000000] CPU 0 irqstacks,
hard=f5806000 soft=f5808000 [ 0.000000] Interrupt pipeline (release
#3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console
[tty0] enabled [ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1694.459 MHz processor. [ 0.008002]
Calibrating delay loop (skipped), value calculated using timer
frequency.. 3388.91 BogoMIPS (lpj=6777836) [ 0.008009] pid_max:
default: 32768 minimum: 301 [ 0.008074] Security Framework
initialized [ 0.008082] AppArmor: AppArmor disabled by boot time
parameter [ 0.008107] Mount-cache hash table entries: 512
[ 0.008407] Initializing cgroup subsys cpuacct [ 0.008411]
Initializing cgroup subsys memory [ 0.008424] Initializing cgroup
subsys devices [ 0.008427] Initializing cgroup subsys freezer
[ 0.008431] Initializing cgroup subsys net_cls [ 0.008434]
Initializing cgroup subsys blkio [ 0.008445] Initializing cgroup
subsys perf_event [ 0.008479] Disabled fast string operations
[ 0.008487] mce: CPU supports 5 MCE banks [ 0.008496] CPU0:
Thermal monitoring enabled (TM2) [ 0.008570] SMP alternatives:
switching to UP code [ 0.012812] Freeing SMP alternatives: 16k freed
[ 0.012819] ACPI: Core revision 20120320
[ 0.017087] ACPI: setting ELCR to 0200 (from 0c20)
[ 0.020066] weird, boot CPU (#0) not listed by the BIOS.
[ 0.020069] SMP motherboard not detected.
[ 0.020074] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.024001] SMP disabled
[ 0.024001] Performance Events: p6 PMU driver.
[ 0.024001] ... version: 0
[ 0.024001] ... bit width: 32
[ 0.024001] ... generic registers: 2
[ 0.024001] ... value mask: 00000000ffffffff
[ 0.024001] ... max period: 000000007fffffff
[ 0.024001] ... fixed-purpose events: 0
[ 0.024001] ... event mask: 0000000000000003
[ 0.032028] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.032071] Brought up 1 CPUs
[ 0.032075] Total of 1 processors activated (3388.91 BogoMIPS).
[ 0.032256] devtmpfs: initialized
[ 0.032632] PM: Registering ACPI NVS region [mem
0x3fff0c00-0x3fffbfff] (46080 bytes) [ 0.032773] dummy: [
0.032849] NET: Registered protocol family 16
[ 0.033045] ACPI: bus type pci registered
[ 0.034613] PCI: PCI BIOS revision 2.10 entry at 0xf031f, last bus=3
[ 0.034616] PCI: Using configuration type 1 for base access
[ 0.035502] bio: create slab <bio-0> at 0
[ 0.035620] ACPI: Added _OSI(Module Device)
[ 0.035624] ACPI: Added _OSI(Processor Device)
[ 0.035628] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.035632] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.037626] ACPI: EC: Look up EC in DSDT
[ 0.049762] ACPI: EC: GPE storm detected, transactions will use
polling mode [ 0.208038] ACPI: Interpreter enabled
[ 0.208054] ACPI: (supports S0 S3 S4 S5)
[ 0.208088] ACPI: Using PIC for interrupt routing
[ 0.210398] ACPI: Power Resource [C18D] (on)
[ 0.211162] ACPI: Power Resource [C195] (on)
[ 0.211943] ACPI: Power Resource [C19C] (on)
[ 0.248176] ACPI: Power Resource [C1A6] (on)
[ 0.288697] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data =
0x62 [ 0.288969] ACPI: No dock devices found.
[ 0.288977] PCI: Ignoring host bridge windows from ACPI; if
necessary, use "pci=use_crs" and report a bug [ 0.295320] ACPI: PCI
Root Bridge [C046] (domain 0000 [bus 00-ff]) [ 0.307926] pci_root
PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.307931] pci_root PNP0A03:00: host bridge window [io
0x0d00-0xffff] (ignored) [ 0.307936] pci_root PNP0A03:00: host
bridge window [mem 0x000a0000-0x000bffff] (ignored) [ 0.307940]
pci_root PNP0A03:00: host bridge window [mem 0x40000000-0xfec00fff]
(ignored) [ 0.307944] pci_root PNP0A03:00: host bridge window [mem
0xfec02000-0xffffffff] (ignored) [ 0.307949] pci_root PNP0A03:00:
host bridge window [mem 0x000d0000-0x000dffff] (ignored) [ 0.307953]
PCI: root bus 00: using default resources [ 0.308002] PCI host
bridge to bus 0000:00 [ 0.308007] pci_bus 0000:00: root bus resource
[io 0x0000-0xffff] [ 0.308011] pci_bus 0000:00: root bus resource
[mem 0x00000000-0xffffffff] [ 0.308037] pci 0000:00:00.0:
[8086:3340] type 00 class 0x060000 [ 0.308049] pci 0000:00:00.0: reg
10: [mem 0xb0000000-0xbfffffff pref] [ 0.308098] pci 0000:00:01.0:
[8086:3341] type 01 class 0x060400 [ 0.308166] pci 0000:00:1d.0:
[8086:24c2] type 00 class 0x0c0300 [ 0.308217] pci 0000:00:1d.0: reg
20: [io 0x48c0-0x48df] [ 0.308255] pci 0000:00:1d.1: [8086:24c4]
type 00 class 0x0c0300 [ 0.308306] pci 0000:00:1d.1: reg 20: [io
0x48e0-0x48ff] [ 0.308347] pci 0000:00:1d.2: [8086:24c7] type 00
class 0x0c0300 [ 0.308398] pci 0000:00:1d.2: reg 20: [io
0x4c00-0x4c1f] [ 0.308448] pci 0000:00:1d.7: [8086:24cd] type 00
class 0x0c0320 [ 0.308474] pci 0000:00:1d.7: reg 10: [mem
0xa0000000-0xa00003ff] [ 0.308563] pci 0000:00:1d.7: PME# supported
from D0 D3hot D3cold [ 0.308588] pci 0000:00:1e.0: [8086:2448] type
01 class 0x060400 [ 0.308636] pci 0000:00:1f.0: [8086:24cc] type 00
class 0x060100 [ 0.308711] pci 0000:00:1f.0: quirk: [io
0x1000-0x107f] claimed by ICH4 ACPI/GPIO/TCO [ 0.308718] pci
0000:00:1f.0: quirk: [io 0x1100-0x113f] claimed by ICH4 GPIO
[ 0.308737] pci 0000:00:1f.1: [8086:24ca] type 00 class 0x01018a
[ 0.308754] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.308766] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.308778] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.308790] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.308802] pci 0000:00:1f.1: reg 20: [io 0x4c40-0x4c4f]
[ 0.308815] pci 0000:00:1f.1: reg 24: [mem 0x00000000-0x000003ff]
[ 0.308849] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[ 0.308900] pci 0000:00:1f.3: reg 20: [io 0x4c20-0x4c3f]
[ 0.308943] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[ 0.308962] pci 0000:00:1f.5: reg 10: [io 0x4000-0x40ff]
[ 0.308974] pci 0000:00:1f.5: reg 14: [io 0x4880-0x48bf]
[ 0.308985] pci 0000:00:1f.5: reg 18: [mem 0xa0200000-0xa02001ff]
[ 0.308997] pci 0000:00:1f.5: reg 1c: [mem 0xa0300000-0xa03000ff]
[ 0.309041] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.309063] pci 0000:00:1f.6: [8086:24c6] type 00 class 0x070300
[ 0.309082] pci 0000:00:1f.6: reg 10: [io 0x4400-0x44ff]
[ 0.309093] pci 0000:00:1f.6: reg 14: [io 0x4800-0x487f]
[ 0.309153] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.309186] pci 0000:01:00.0: [1002:4c66] type 00 class 0x030000
[ 0.309204] pci 0000:01:00.0: reg 10: [mem 0x98000000-0x9fffffff
pref] [ 0.309214] pci 0000:01:00.0: reg 14: [io 0x3000-0x30ff]
[ 0.309224] pci 0000:01:00.0: reg 18: [mem 0x90400000-0x9040ffff]
[ 0.309253] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff
pref] [ 0.309277] pci 0000:01:00.0: supports D1 D2 [ 0.309317]
pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.309322] pci
0000:00:01.0: bridge window [io 0x3000-0x3fff] [ 0.309327] pci
0000:00:01.0: bridge window [mem 0x90400000-0x904fffff]
[ 0.309333] pci 0000:00:01.0: bridge window [mem
0x98000000-0x9fffffff pref] [ 0.309360] pci 0000:02:00.0:
[1106:3044] type 00 class 0x0c0010 [ 0.309380] pci 0000:02:00.0: reg
10: [mem 0x90200000-0x902007ff] [ 0.309392] pci 0000:02:00.0: reg
14: [io 0x2400-0x247f] [ 0.309456] pci 0000:02:00.0: supports D2
[ 0.309459] pci 0000:02:00.0: PME# supported from D2 D3hot D3cold
[ 0.309483] pci 0000:02:01.0: [10ec:8139] type 00 class 0x020000
[ 0.309503] pci 0000:02:01.0: reg 10: [io 0x2000-0x20ff]
[ 0.309515] pci 0000:02:01.0: reg 14: [mem 0x90300000-0x903000ff]
[ 0.309577] pci 0000:02:01.0: supports D1 D2 [ 0.309580] pci
0000:02:01.0: PME# supported from D1 D2 D3hot D3cold [ 0.309602] pci
0000:02:02.0: [8086:4220] type 00 class 0x028000 [ 0.309622] pci
0000:02:02.0: reg 10: [mem 0x90000000-0x90000fff] [ 0.309694] pci
0000:02:02.0: PME# supported from D0 D3hot D3cold [ 0.309719] pci
0000:02:04.0: [1524:1410] type 02 class 0x060700 [ 0.309739] pci
0000:02:04.0: reg 10: [mem 0x90100000-0x90100fff] [ 0.309761] pci
0000:02:04.0: supports D1 D2 [ 0.309765] pci 0000:02:04.0: PME#
supported from D0 D1 D2 D3hot D3cold [ 0.309810] pci 0000:00:1e.0:
PCI bridge to [bus 02-03] (subtractive decode) [ 0.309816] pci
0000:00:1e.0: bridge window [io 0x2000-0x2fff] [ 0.309822] pci
0000:00:1e.0: bridge window [mem 0x90000000-0x903fffff]
[ 0.309829] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff]
(subtractive decode) [ 0.309834] pci 0000:00:1e.0: bridge window
[mem 0x00000000-0xffffffff] (subtractive decode) [ 0.309873] pci_bus
0000:03: [bus 03-06] partially hidden behind transparent bridge 0000:02
[bus 02-03] [ 0.309888] pci_bus 0000:00: on NUMA node 0
[ 0.309894] ACPI: PCI Interrupt Routing Table [\_SB_.C046._PRT]
[ 0.309970] ACPI: PCI Interrupt Routing Table [\_SB_.C046.C047._PRT]
[ 0.310005] ACPI: PCI Interrupt Routing Table [\_SB_.C046.C058._PRT]
[ 0.310158] pci0000:00: Unable to request _OSC control (_OSC
support mask: 0x0e) [ 0.321957] ACPI: PCI Interrupt Link [C0C2]
(IRQs 5 *10) [ 0.322112] ACPI: PCI Interrupt Link [C0C3] (IRQs 5
*10) [ 0.322263] ACPI: PCI Interrupt Link [C0C4] (IRQs *5 10)
[ 0.322415] ACPI: PCI Interrupt Link [C0C5] (IRQs *5 10)
[ 0.322551] ACPI: PCI Interrupt Link [C0C6] (IRQs 5 10) *0,
disabled. [ 0.322704] ACPI: PCI Interrupt Link [C0C7] (IRQs 5 10)
*11 [ 0.322843] ACPI: PCI Interrupt Link [C0C8] (IRQs 5 10) *0,
disabled. [ 0.322996] ACPI: PCI Interrupt Link [C0C9] (IRQs *5 10)
[ 0.323139] vgaarb: device added:
PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.323146]
vgaarb: loaded [ 0.323148] vgaarb: bridge control possible
0000:01:00.0 [ 0.323193] PCI: Using ACPI for IRQ routing
[ 0.323197] PCI: pci_cache_line_size set to 64 bytes [ 0.323275]
reserve RAM buffer: 000000000009fc00 - 000000000009ffff [ 0.323279]
reserve RAM buffer: 000000003ffd0000 - 000000003fffffff [ 0.323541]
pnp: PnP ACPI init [ 0.323559] ACPI: bus type pnp registered
[ 0.323688] pnp 00:00: [mem 0x00000000-0x0009ffff] [ 0.323693]
pnp 00:00: [mem 0x000e0000-0x000fffff] [ 0.323697] pnp 00:00: [mem
0x00100000-0x3fffffff] [ 0.323753] system 00:00: [mem
0x00000000-0x0009ffff] could not be reserved [ 0.323759] system
00:00: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.323764]
system 00:00: [mem 0x00100000-0x3fffffff] could not be reserved
[ 0.323769] system 00:00: Plug and Play ACPI device, IDs PNP0c01
(active) [ 0.330103] pnp 00:01: [bus 00-ff] [ 0.330107] pnp
00:01: [io 0x0cf8-0x0cff] [ 0.330111] pnp 00:01: [io 0x0000-0x0cf7
window] [ 0.330115] pnp 00:01: [io 0x0d00-0xffff window]
[ 0.330119] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.330124] pnp 00:01: [mem 0x40000000-0xfec00fff window]
[ 0.330128] pnp 00:01: [mem 0xfec02000-0xffffffff window]
[ 0.330132] pnp 00:01: [mem 0x000d0000-0x000dffff window]
[ 0.330197] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03
(active) [ 0.330426] pnp 00:02: Plug and Play ACPI device, IDs
WEC0518 (disabled) [ 0.331209] pnp 00:03: [io 0x03f8-0x03ff]
[ 0.331214] pnp 00:03: [irq 4] [ 0.331296] pnp 00:03: Plug and
Play ACPI device, IDs PNP0501 PNP0500 (active) [ 0.332182] pnp
00:04: [io 0x03e8-0x03ef] [ 0.332187] pnp 00:04: [io
0x07d0-0x07d7] [ 0.332191] pnp 00:04: [irq 3] [ 0.332194] pnp
00:04: [dma 3] [ 0.332303] pnp 00:04: Plug and Play ACPI device, IDs
SMCf010 PNP0511 (active) [ 0.333168] pnp 00:05: [io 0x0378-0x037f]
[ 0.333172] pnp 00:05: [io 0x0778-0x077a]
[ 0.333176] pnp 00:05: [irq 7]
[ 0.333182] pnp 00:05: [dma 1]
[ 0.333323] pnp 00:05: Plug and Play ACPI device, IDs PNP0401
(active) [ 0.333341] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.333345] pnp 00:06: [irq 13]
[ 0.333388] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04
(active) [ 0.333408] pnp 00:07: [io 0x0000-0x000f]
[ 0.333412] pnp 00:07: [io 0x0080-0x008f]
[ 0.333415] pnp 00:07: [io 0x00c0-0x00df]
[ 0.333419] pnp 00:07: [dma 4]
[ 0.333462] pnp 00:07: Plug and Play ACPI device, IDs PNP0200
(active) [ 0.333479] pnp 00:08: [io 0x0061]
[ 0.333524] pnp 00:08: Plug and Play ACPI device, IDs PNP0800
(active) [ 0.333540] pnp 00:09: [io 0x0070-0x0071]
[ 0.333544] pnp 00:09: [io 0x0072-0x0073]
[ 0.333548] pnp 00:09: [irq 8]
[ 0.333591] pnp 00:09: Plug and Play ACPI device, IDs PNP0b00
(active) [ 0.333608] pnp 00:0a: [io 0x0060]
[ 0.333611] pnp 00:0a: [io 0x0064]
[ 0.333615] pnp 00:0a: [irq 1]
[ 0.333666] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303
(active) [ 0.333683] pnp 00:0b: [irq 12]
[ 0.333740] pnp 00:0b: Plug and Play ACPI device, IDs SYN0107
SYN0100 SYN0002 PNP0f13 (active) [ 0.333828] pnp 00:0c: [io
0x0010-0x001f] [ 0.333832] pnp 00:0c: [io 0x0024-0x003f]
[ 0.333836] pnp 00:0c: [io 0x002e-0x002f]
[ 0.333839] pnp 00:0c: [io 0x0050-0x0053]
[ 0.333843] pnp 00:0c: [io 0x0068-0x006f]
[ 0.333846] pnp 00:0c: [io 0x0074-0x0077]
[ 0.333850] pnp 00:0c: [io 0x0090-0x009f]
[ 0.333855] pnp 00:0c: [io 0x00a4-0x00bd]
[ 0.333859] pnp 00:0c: [io 0x0140-0x014f]
[ 0.333862] pnp 00:0c: [mem 0xffb00000-0xffbfffff]
[ 0.333866] pnp 00:0c: [mem 0xfff00000-0xffffffff]
[ 0.333870] pnp 00:0c: [io 0x004c-0x004d]
[ 0.333874] pnp 00:0c: [io 0x004e-0x004f]
[ 0.333877] pnp 00:0c: [io 0x0200-0x020f]
[ 0.333958] system 00:0c: [io 0x0140-0x014f] has been reserved
[ 0.333963] system 00:0c: [io 0x0200-0x020f] has been reserved
[ 0.333970] system 00:0c: [mem 0xffb00000-0xffbfffff] has been
reserved [ 0.333975] system 00:0c: [mem 0xfff00000-0xffffffff] has
been reserved [ 0.333980] system 00:0c: Plug and Play ACPI device,
IDs PNP0c02 (active) [ 0.334548] pnp 00:0d: [io 0x04d0-0x04d1]
[ 0.334552] pnp 00:0d: [io 0x1000-0x107f]
[ 0.334556] pnp 00:0d: [io 0x1100-0x113f]
[ 0.334560] pnp 00:0d: [io 0x1200-0x121f]
[ 0.334563] pnp 00:0d: [mem 0xfec00000-0xfec000ff]
[ 0.334652] system 00:0d: [io 0x04d0-0x04d1] has been reserved
[ 0.334657] system 00:0d: [io 0x1000-0x107f] has been reserved
[ 0.334662] system 00:0d: [io 0x1100-0x113f] has been reserved
[ 0.334666] system 00:0d: [io 0x1200-0x121f] has been reserved
[ 0.334671] system 00:0d: [mem 0xfec00000-0xfec000ff] has been
reserved [ 0.334676] system 00:0d: Plug and Play ACPI device, IDs
PNP0c02 (active) [ 0.334908] pnp 00:0e: [mem 0xfec01000-0xfec01fff]
[ 0.334994] system 00:0e: [mem 0xfec01000-0xfec01fff] has been
reserved [ 0.334999] system 00:0e: Plug and Play ACPI device, IDs
PNP0c02 (active) [ 0.335008] pnp: PnP ACPI: found 15 devices
[ 0.335011] ACPI: ACPI bus type pnp unregistered
[ 0.335015] PnPBIOS: Disabled by ACPI PNP
[ 0.371963] Switching to clocksource acpi_pm
[ 0.372006] pci 0000:02:04.0: res[15]=[mem 0x04000000-0x03ffffff
pref] get_res_add_size add_size 4000000 [ 0.372012] pci
0000:00:1e.0: bridge window [mem 0x04000000-0x03ffffff pref] to [bus
02-03] add_size 4000000 [ 0.372012] pci 0000:00:1e.0: res[15]=[mem
0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000
[ 0.372012] pci 0000:00:1e.0: BAR 15: assigned [mem
0x40000000-0x43ffffff pref] [ 0.372012] pci 0000:00:1f.1: BAR 5:
assigned [mem 0x44000000-0x440003ff] [ 0.372012] pci 0000:01:00.0:
BAR 6: assigned [mem 0x90420000-0x9043ffff pref] [ 0.372012] pci
0000:00:01.0: PCI bridge to [bus 01-01] [ 0.372012] pci
0000:00:01.0: bridge window [io 0x3000-0x3fff] [ 0.372012] pci
[ 0.372012] pci 0000:00:01.0: bridge window [mem
0x98000000-0x9fffffff pref] [ 0.372012] pci 0000:02:04.0:
res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size
4000000 [ 0.372012] pci 0000:02:04.0: res[16]=[mem
0x04000000-0x03ffffff] get_res_add_size add_size 4000000 [ 0.372012]
pci 0000:02:04.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size
100 [ 0.372012] pci 0000:02:04.0: res[14]=[io 0x0100-0x00ff]
get_res_add_size add_size 100 [ 0.372012] pci 0000:02:04.0: BAR 15:
assigned [mem 0x40000000-0x43ffffff pref] [ 0.372012] pci
0000:02:04.0: BAR 16: assigned [mem 0x48000000-0x4bffffff]
[ 0.372012] pci 0000:02:04.0: BAR 13: assigned [io 0x2800-0x28ff]
[ 0.372012] pci 0000:02:04.0: BAR 14: assigned [io 0x2c00-0x2cff]
[ 0.372012] pci 0000:02:04.0: CardBus bridge to [bus 03-06]
[ 0.372012] pci 0000:02:04.0: bridge window [io 0x2800-0x28ff]
[ 0.372012] pci 0000:02:04.0: bridge window [io 0x2c00-0x2cff]
[ 0.372012] pci 0000:02:04.0: bridge window [mem
0x40000000-0x43ffffff pref] [ 0.372012] pci 0000:02:04.0: bridge
window [mem 0x48000000-0x4bffffff] [ 0.372012] pci 0000:00:1e.0: PCI
bridge to [bus 02-03] [ 0.372012] pci 0000:00:1e.0: bridge window
[io 0x2000-0x2fff] [ 0.372012] pci 0000:00:1e.0: bridge window
[mem 0x90000000-0x903fffff] [ 0.372012] pci 0000:00:1e.0: bridge
window [mem 0x40000000-0x43ffffff pref] [ 0.372012] pci
0000:00:1e.0: setting latency timer to 64 [ 0.372012] ACPI: PCI
Interrupt Link [C0C4] enabled at IRQ 5 [ 0.372012] PCI: setting IRQ
5 as level-triggered [ 0.372012] pci_bus 0000:00: resource 4 [io
0x0000-0xffff] [ 0.372012] pci_bus 0000:00: resource 5 [mem
0x00000000-0xffffffff] [ 0.372012] pci_bus 0000:01: resource 0 [io
0x3000-0x3fff] [ 0.372012] pci_bus 0000:01: resource 1 [mem
0x90400000-0x904fffff] [ 0.372012] pci_bus 0000:01: resource 2 [mem
0x98000000-0x9fffffff pref] [ 0.372012] pci_bus 0000:02: resource 0
[io 0x2000-0x2fff] [ 0.372012] pci_bus 0000:02: resource 1 [mem
0x90000000-0x903fffff] [ 0.372012] pci_bus 0000:02: resource 2 [mem
0x40000000-0x43ffffff pref] [ 0.372012] pci_bus 0000:02: resource 4
[io 0x0000-0xffff] [ 0.372012] pci_bus 0000:02: resource 5 [mem
0x00000000-0xffffffff] [ 0.372012] pci_bus 0000:03: resource 0 [io
0x2800-0x28ff] [ 0.372012] pci_bus 0000:03: resource 1 [io
0x2c00-0x2cff] [ 0.372012] pci_bus 0000:03: resource 2 [mem
0x40000000-0x43ffffff pref] [ 0.372012] pci_bus 0000:03: resource 3
[mem 0x48000000-0x4bffffff] [ 0.372012] NET: Registered protocol
family 2 [ 0.372012] IP route cache hash table entries: 32768
(order: 5, 131072 bytes) [ 0.372012] TCP established hash table
entries: 131072 (order: 8, 1048576 bytes) [ 0.372012] TCP bind hash
table entries: 65536 (order: 7, 524288 bytes) [ 0.372012] TCP: Hash
tables configured (established 131072 bind 65536) [ 0.372012] TCP:
reno registered [ 0.372012] UDP hash table entries: 512 (order: 2,
16384 bytes) [ 0.372012] UDP-Lite hash table entries: 512 (order: 2,
16384 bytes) [ 0.372012] NET: Registered protocol family 1
[ 0.372012] ACPI: PCI Interrupt Link [C0C2] enabled at IRQ 10
[ 0.372012] PCI: setting IRQ 10 as level-triggered [ 0.372012]
ACPI: PCI Interrupt Link [C0C5] enabled at IRQ 5 [ 0.372012] ACPI:
PCI Interrupt Link [C0C9] enabled at IRQ 5 [ 0.372012] pci
0000:01:00.0: Boot video device [ 0.372012] PCI: CLS 32 bytes,
default 64 [ 0.372012] Unpacking initramfs... [ 0.818658] Freeing
initrd memory: 13704k freed [ 0.840637] audit: initializing netlink
socket (disabled) [ 0.840663] type=2000 audit(1478357014.840:1):
initialized [ 0.857293] highmem bounce pool size: 64 pages
[ 0.857302] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.857502] VFS: Disk quotas dquot_6.5.2 [ 0.857537] Dquot-cache
hash table entries: 1024 (order 0, 4096 bytes) [ 0.857650] msgmni
has been set to 1741 [ 0.857882] alg: No test for stdrng (krng)
[ 0.857917] Block layer SCSI generic (bsg) driver version 0.4 loaded
(major 253) [ 0.857923] io scheduler noop registered [ 0.857926]
io scheduler deadline registered [ 0.857945] io scheduler cfq
registered (default) [ 0.858090] pci_hotplug: PCI Hot Plug PCI Core
version: 0.5 [ 0.858117] pciehp: PCI Express Hot Plug Controller
Driver version: 0.4 [ 0.858121] acpiphp: ACPI Hot Plug PCI
Controller Driver version: 0.5 [ 0.858752] GHES: HEST is not
enabled! [ 0.858770] isapnp: Scanning for PnP cards...
[ 1.212548] isapnp: No Plug & Play device found [ 1.212614]
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.232931]
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.253306]
serial8250: ttyS2 at I/O 0x3e8 (irq = 4) is a 16550A [ 1.273803]
00:03: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.274288] ACPI:
PCI Interrupt Link [C0C3] enabled at IRQ 10 [ 1.274429] Linux
agpgart interface v0.103 [ 1.274616] agpgart-intel 0000:00:00.0:
Intel 855PM Chipset [ 1.288739] agpgart-intel 0000:00:00.0: AGP
aperture is 256M @ 0xb0000000 [ 1.288952] i8042: PNP: PS/2
Controller [PNP0303:C1A3,PNP0f13:C1A4] at 0x60,0x64 irq 1,12
[ 1.298846] i8042: Detected active multiplexing controller, rev 1.1
[ 1.305582] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.305630]
serio: i8042 AUX0 port at 0x60,0x64 irq 12 [ 1.305666] serio: i8042
AUX1 port at 0x60,0x64 irq 12 [ 1.305701] serio: i8042 AUX2 port at
0x60,0x64 irq 12 [ 1.305738] serio: i8042 AUX3 port at 0x60,0x64 irq
12 [ 1.305861] mousedev: PS/2 mouse device common for all mice
[ 1.306032] rtc_cmos 00:09: RTC can wake from S4 [ 1.306164]
rtc_cmos 00:09: rtc core: registered rtc_cmos as rtc0 [ 1.306184]
rtc0: alarms up to one month, y3k, 114 bytes nvram [ 1.306391] TCP:
cubic registered [ 1.306448] NET: Registered protocol family 10
[ 1.306746] Mobile IPv6
[ 1.306751] NET: Registered protocol family 17
[ 1.306759] Registering the dns_resolver key type
[ 1.306837] Using IPI No-Shortcut mode
[ 1.306948] PM: Hibernation image not present or could not be loaded.
[ 1.306971] registered taskstats version 1
[ 1.307342] rtc_cmos 00:09: setting system clock to 2016-11-05
14:43:35 UTC (1478357015) [ 1.307448] Freeing unused kernel memory:
416k freed [ 1.307729] Write protecting the kernel text: 3496k
[ 1.307758] Write protecting the kernel read-only data: 984k
[ 1.325058] udevd[45]: starting version 175
[ 1.328275] input: AT Translated Set 2 keyboard
as /devices/platform/i8042/serio0/input/input0 [ 1.371236] usbcore:
registered new interface driver usbfs [ 1.371275] usbcore:
registered new interface driver hub [ 1.416191] usbcore: registered
new device driver usb [ 1.425950] ehci_hcd: USB 2.0 'Enhanced' Host
Controller (EHCI) Driver [ 1.426051] ehci_hcd 0000:00:1d.7: setting
latency timer to 64 [ 1.426057] ehci_hcd 0000:00:1d.7: EHCI Host
Controller [ 1.426103] ehci_hcd 0000:00:1d.7: new USB bus
registered, assigned bus number 1 [ 1.426144] ehci_hcd 0000:00:1d.7:
debug port 1 [ 1.429786] uhci_hcd: USB Universal Host Controller
Interface driver [ 1.441818] 8139cp: 8139cp: 10/100 PCI Ethernet
driver v1.3 (Mar 22, 2004) [ 1.442425] 8139cp 0000:02:01.0: eth0:
RTL-8139C+ at 0xf800c000, 00:0f:b0:0e:e8:4e, IRQ 10 [ 1.446121] SCSI
subsystem initialized [ 1.450449] ehci_hcd 0000:00:1d.7: cache line
size of 32 is not supported [ 1.450473] ehci_hcd 0000:00:1d.7: irq
5, io mem 0xa0000000 [ 1.452927] 8139too: 8139too Fast Ethernet
driver 0.9.28 [ 1.459225] libata version 3.00 loaded.
[ 1.460252] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.460330] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002 [ 1.460335] usb usb1: New USB device strings: Mfr=3,
Product=2, SerialNumber=1 [ 1.460339] usb usb1: Product: EHCI Host
Controller [ 1.460343] usb usb1: Manufacturer: Linux
3.4-9-rtai-686-pae ehci_hcd [ 1.460346] usb usb1: SerialNumber:
0000:00:1d.7 [ 1.460541] hub 1-0:1.0: USB hub found
[ 1.460550] hub 1-0:1.0: 6 ports detected
[ 1.461490] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.461496] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.461515] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned
bus number 2 [ 1.461550] uhci_hcd 0000:00:1d.0: irq 10, io base
0x000048c0 [ 1.461603] usb usb2: New USB device found,
idVendor=1d6b, idProduct=0001 [ 1.461607] usb usb2: New USB device
strings: Mfr=3, Product=2, SerialNumber=1 [ 1.461611] usb usb2:
Product: UHCI Host Controller [ 1.461614] usb usb2: Manufacturer:
Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.461618] usb usb2:
SerialNumber: 0000:00:1d.0 [ 1.461779] hub 2-0:1.0: USB hub found
[ 1.461786] hub 2-0:1.0: 2 ports detected
[ 1.461925] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.461931] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.461941] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned
bus number 3 [ 1.461968] uhci_hcd 0000:00:1d.1: irq 5, io base
0x000048e0 [ 1.462016] usb usb3: New USB device found,
idVendor=1d6b, idProduct=0001 [ 1.462020] usb usb3: New USB device
strings: Mfr=3, Product=2, SerialNumber=1 [ 1.462024] usb usb3:
Product: UHCI Host Controller [ 1.462027] usb usb3: Manufacturer:
Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.462031] usb usb3:
SerialNumber: 0000:00:1d.1 [ 1.462166] hub 3-0:1.0: USB hub found
[ 1.462173] hub 3-0:1.0: 2 ports detected
[ 1.462284] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.462289] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.462300] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned
bus number 4 [ 1.462326] uhci_hcd 0000:00:1d.2: irq 5, io base
0x00004c00 [ 1.462373] usb usb4: New USB device found,
idVendor=1d6b, idProduct=0001 [ 1.462378] usb usb4: New USB device
strings: Mfr=3, Product=2, SerialNumber=1 [ 1.462381] usb usb4:
Product: UHCI Host Controller [ 1.462385] usb usb4: Manufacturer:
Linux 3.4-9-rtai-686-pae uhci_hcd [ 1.462388] usb usb4:
SerialNumber: 0000:00:1d.2 [ 1.462530] hub 4-0:1.0: USB hub found
[ 1.462537] hub 4-0:1.0: 2 ports detected
[ 1.462937] ata_piix 0000:00:1f.1: version 2.13
[ 1.462951] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 1.463014] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.468135] scsi0 : ata_piix
[ 1.471394] scsi1 : ata_piix
[ 1.487374] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x4c40
irq 14 [ 1.487380] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma
0x4c48 irq 15 [ 1.503682] wbsd: Winbond W83L51xD SD/MMC card
interface driver [ 1.503687] wbsd: Copyright(c) Pierre Ossman
[ 1.503723] wbsd 00:02: [io 0x0248-0x024f]
[ 1.503788] wbsd 00:02: [irq 6]
[ 1.503793] wbsd 00:02: [dma 0]
[ 1.507194] wbsd 00:02: activated
[ 1.516127] firewire_ohci 0000:02:00.0: added OHCI v1.0 device as
card 0, 4 IR + 8 IT contexts, quirks 0x11 [ 1.517494] mmc0: W83L51xD
id 7112 at 0x248 irq 6 dma 0 PnP [ 1.527379] microcode: CPU0
sig=0x6d6, pf=0x20, revision=0x17 [ 1.571365] microcode: CPU0
updated to revision 0x18, date = 2004-10-17 [ 1.571687] microcode:
Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter
Oruba [ 1.648714] ata1.00: ATA-6: IC25N040ATMR04-0, MO2OAD0A, max
UDMA/100 [ 1.648719] ata1.00: 78140160 sectors, multi 16: LBA48
[ 1.656450] ata2.00: ATAPI: SONY DVD+RW DW-P50A, 1.8f, max
UDMA/33 [ 1.664443] ata1.00: configured for UDMA/100 [ 1.664619]
scsi 0:0:0:0: Direct-Access ATA IC25N040ATMR04-0 MO2O PQ: 0
ANSI: 5 [ 1.672168] ata2.00: configured for UDMA/33 [ 1.673845]
scsi 1:0:0:0: CD-ROM SONY DVD+RW DW-P50A 1.8f PQ: 0
ANSI: 5 [ 1.683799] sd 0:0:0:0: [sda] 78140160 512-byte logical
blocks: (40.0 GB/37.2 GiB) [ 1.683884] sd 0:0:0:0: [sda] Write
Protect is off [ 1.683889] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.683924] sd 0:0:0:0: [sda] Write cache: enabled, read cache:
enabled, doesn't support DPO or FUA [ 1.730371] sda: sda1 sda2 <
sda5 > sda3 [ 1.730817] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.733106] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda
tray [ 1.733112] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.733622] sr 1:0:0:0: Attached scsi CD-ROM sr0 [ 1.735586] sd
0:0:0:0: Attached scsi generic sg0 type 0 [ 1.735677] sr 1:0:0:0:
Attached scsi generic sg1 type 5 [ 1.848025] Refined TSC clocksource
calibration: 1694.501 MHz. [ 1.848035] Switching to clocksource tsc
[ 2.016160] firewire_core 0000:02:00.0: created device fw0: GUID
00023f494a4062f7, S400 [ 2.128019] usb 4-2: new full-speed USB
device number 2 using uhci_hcd [ 2.328230] usb 4-2: New USB device
found, idVendor=049f, idProduct=0086 [ 2.328236] usb 4-2: New USB
device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.328241] usb
4-2: Product: Bluetooth by hp [ 2.328244] usb 4-2: Manufacturer:
ACTIONTEC [ 7.263715] PM: Starting manual resume from disk
[ 7.263721] PM: Hibernation image partition 8:5 present
[ 7.263724] PM: Looking for hibernation image.
[ 7.263938] PM: Image not found (code -22)
[ 7.263942] PM: Hibernation image not present or could not be loaded.
[ 7.323236] EXT4-fs (sda1): mounted filesystem with ordered data
mode. Opts: (null) [ 9.752774] udevd[335]: starting version 175
[ 10.128180] input: Power Button
as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 10.128192] ACPI: Power Button [C1BE] [ 10.128302] input: Lid
Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 10.128401] ACPI: Lid Switch [C136] [ 10.128479] input: Power
Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 10.128485]
ACPI: Power Button [PWRF] [ 10.169256] shpchp: Standard Hot Plug PCI
Controller Driver version: 0.4 [ 10.704347] ACPI: Battery Slot [C11F]
(battery present) [ 10.706136] ACPI: AC Adapter [C134] (on-line)
[ 10.821904] intel_rng: FWH not detected
[ 11.032663] input: Video Bus
as
/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input4
[ 11.033125] ACPI: Video Device [C0D0] (multi-head: yes rom: no
post: no) [ 11.123647] iTCO_vendor_support: vendor-support=0
[ 11.124952] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.125054] iTCO_wdt: Found a ICH4-M TCO device (Version=1,
TCOBASE=0x1060) [ 11.125962] iTCO_wdt: initialized. heartbeat=30 sec
(nowayout=0) [ 11.253133] NET: Registered protocol family 23
[ 11.467840] Detected unconfigured Compaq x1000 family SMSC IrDA
chip, pre-configuring device. [ 11.467845] Setting up Intel 82801
controller and SMSC device [ 11.467977] found SMC SuperIO Chip
(devid=0x5a rev=00 base=0x002e): LPC47N227 [ 11.467994]
smsc_superio_flat(): fir: 0x2f8, sir: 0x2e8, dma: 03, irq: 7, mode:
0x0e [ 11.468020] SMsC IrDA Controller found [ 11.468022] IrCC
version 2.0, firport 0x2f8, sirport 0x2e8 dma=3, irq=7 [ 11.468090]
No transceiver found. Defaulting to Fast pin select [ 11.469832]
IrDA: Registered device irda0 [ 11.537375] parport_pc 00:05: reported
by Plug and Play ACPI [ 11.537426] parport0: PC-style at 0x378
(0x778), irq 7 [PCSPP,TRISTATE] [ 11.541139] yenta_cardbus
0000:02:04.0: CardBus bridge found [0e11:0860] [ 11.541160]
yenta_cardbus 0000:02:04.0: Using CSCINT to route CSC interrupts to PCI
[ 11.541164] yenta_cardbus 0000:02:04.0: Routing CardBus interrupts
to PCI [ 11.541171] yenta_cardbus 0000:02:04.0: TI: mfunc 0x001c1112,
devctl 0x44 [ 11.574217] Bluetooth: Core ver 2.16 [ 11.574443] NET:
Registered protocol family 31 [ 11.574447] Bluetooth: HCI device and
connection manager initialized [ 11.574451] Bluetooth: HCI socket
layer initialized [ 11.574454] Bluetooth: L2CAP socket layer
initialized [ 11.574462] Bluetooth: SCO socket layer initialized
[ 11.597868] cfg80211: Calling CRDA to update world regulatory domain
[ 11.669208] usbcore: registered new interface driver btusb
[ 11.680252] lib80211: common routines for IEEE802.11 drivers
[ 11.680258] lib80211_crypt: registered algorithm
'NULL' [ 11.699792] libipw: 802.11 data/management/control stack,
git-1.1.13 [ 11.699796] libipw: Copyright (C) 2004-2005 Intel
Corporation <jketreno@linux.intel.com> [ 11.745302] [drm] Initialized
drm 1.1.0 20060810 [ 11.772343] yenta_cardbus 0000:02:04.0: ISA IRQ
mask 0x0818, PCI irq 5 [ 11.772348] yenta_cardbus 0000:02:04.0:
Socket status: 30000006 [ 11.772355] pci_bus 0000:02: Raising
subordinate bus# of parent bus (#02) from #03 to #06 [ 11.772368]
yenta_cardbus 0000:02:04.0: pcmcia: parent PCI bridge window: [io
0x2000-0x2fff] [ 11.772373] pcmcia_socket pcmcia_socket0: cs: IO port
probe 0x2000-0x2fff: excluding 0x2000-0x20ff 0x2400-0x247f
0x2800-0x28ff 0x2c00-0x2cff [ 11.780000] yenta_cardbus 0000:02:04.0:
pcmcia: parent PCI bridge window: [mem 0x90000000-0x903fffff]
[ 11.780017] pcmcia_socket pcmcia_socket0: cs: memory probe
0x90000000-0x903fffff: excluding 0x90000000-0x9003ffff
0x90100000-0x9013ffff 0x90200000-0x9023ffff 0x90300000-0x9033ffff
[ 11.780049] yenta_cardbus 0000:02:04.0: pcmcia: parent PCI bridge
window: [mem 0x40000000-0x43ffffff pref] [ 11.780054] pcmcia_socket
pcmcia_socket0: cs: memory probe 0x40000000-0x43ffffff: excluding
0x40000000-0x43ffffff [ 11.958776] ipw2200: Intel(R) PRO/Wireless
2200/2915 Network Driver, 1.2.2kmprq [ 11.958781] ipw2200:
Copyright(c) 2003-2006 Intel Corporation [ 11.958959] ipw2200:
Detected Intel PRO/Wireless 2200BG Network Connection [ 12.103581]
[drm] radeon kernel modesetting enabled. [ 12.105357] [drm]
initializing kernel modesetting (RV250 0x1002:0x4C66 0x0E11:0x0860).
[ 12.105388] [drm] register mmio base: 0x90400000 [ 12.105391]
[drm] register mmio size: 65536 [ 12.105862] agpgart-intel
0000:00:00.0: AGP 2.0 bridge [ 12.105878] agpgart-intel 0000:00:00.0:
putting AGP V2 device into 4x mode [ 12.105923] radeon 0000:01:00.0:
putting AGP V2 device into 4x mode [ 12.105952] radeon 0000:01:00.0:
GTT: 256M 0xB0000000 - 0xBFFFFFFF [ 12.105962] radeon 0000:01:00.0:
VRAM: 128M 0x0000000098000000 - 0x000000009FFFFFFF (64M used)
[ 12.106356] [drm] Detected VRAM RAM=128M, BAR=128M [ 12.106362]
[drm] RAM width 128bits DDR [ 12.106460] [TTM] Zone kernel:
Available graphics memory: 446142 kiB [ 12.106464] [TTM] Zone
highmem: Available graphics memory: 515682 kiB [ 12.106467] [TTM]
Initializing pool allocator [ 12.106516] [drm] radeon: 64M of VRAM
memory ready [ 12.106520] [drm] radeon: 256M of GTT memory ready.
[ 12.106551] [drm] radeon: ib pool ready. [ 12.108324] radeon
0000:01:00.0: WB disabled [ 12.108334] [drm] fence driver on ring 0
use gpu addr 0xb0000000 and cpu addr 0xf802e000 [ 12.108340] [drm]
Supports vblank timestamp caching Rev 1 (10.10.2010). [ 12.108343]
[drm] Driver supports precise vblank timestamp query. [ 12.108362]
[drm] radeon: irq initialized. [ 12.109081] [drm] Loading R200
Microcode [ 12.220117] psmouse serio4: synaptics: Touchpad model: 1,
fw: 5.9, id: 0x236eb3, caps: 0x904713/0x10008/0x0 [ 12.272972] input:
SynPS/2 Synaptics TouchPad
as /devices/platform/i8042/serio4/input/input5 [ 12.302401]
snd_intel8x0 0000:00:1f.5: setting latency timer to 64 [ 12.402094]
pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding
0x140-0x14f 0x170-0x177 0x1f0-0x1f7 0x200-0x20f 0x248-0x24f 0x2e8-0x2ef
0x2f8-0x2ff 0x370-0x37f [ 12.403794] pcmcia_socket pcmcia_socket0:
cs: IO port probe 0x3e0-0x4ff: excluding 0x3e8-0x3ff 0x4d0-0x4d7
[ 12.404551] pcmcia_socket pcmcia_socket0: cs: IO port probe
0x820-0x8ff: clean. [ 12.405190] pcmcia_socket pcmcia_socket0: cs: IO
port probe 0xc00-0xcf7: clean. [ 12.405906] pcmcia_socket
pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding
0xc0000-0xcffff 0xe0000-0xfffff [ 12.405952] pcmcia_socket
pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: excluding
0xa0000000-0xa00fffff 0xa0200000-0xa03fffff [ 12.406000]
pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff:
clean. [ 12.406044] pcmcia_socket pcmcia_socket0: cs: IO port probe
0xa00-0xaff: clean. [ 12.727680] [drm] radeon: ring at
0x00000000B0001000 [ 12.727704] [drm] ring test succeeded in 1 usecs
[ 12.727976] [drm] ib test succeeded in 0 usecs [ 12.728231] [drm]
Panel ID String: LGP [ 12.728235] [drm] Panel Size 1280x800
[ 12.747165] [drm] radeon legacy LVDS backlight initialized
[ 12.747173] [drm] No TV DAC info found in BIOS [ 12.752251] [drm]
Radeon Display Connectors [ 12.752254] [drm] Connector 0:
[ 12.752257] [drm] VGA [ 12.752261] [drm] DDC: 0x60 0x60 0x60
0x60 0x60 0x60 0x60 0x60 [ 12.752264] [drm] Encoders:
[ 12.752266] [drm] CRT1: INTERNAL_DAC1 [ 12.752269] [drm]
Connector 1: [ 12.752272] [drm] LVDS [ 12.752275] [drm] DDC:
0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c 0x6c [ 12.752278] [drm]
Encoders: [ 12.752280] [drm] LCD1: INTERNAL_LVDS [ 12.752283]
[drm] Connector 2: [ 12.752286] [drm] S-video [ 12.752288]
[drm] Encoders: [ 12.752290] [drm] TV1: INTERNAL_DAC2
[ 12.752313] [drm] radeon: power management initialized
[ 12.865794] [drm] fb mappable at 0x98040000 [ 12.865800] [drm]
vram apper at 0x98000000 [ 12.865803] [drm] size 4096000
[ 12.865805] [drm] fb depth is 24 [ 12.865808] [drm] pitch is
5120 [ 12.866117] fbcon: radeondrmfb (fb0) is primary device
[ 12.889143] cfg80211: failed to add phy80211 symlink to netdev!
[ 12.889375] ipw2200: Detected geography ZZR (14 802.11bg channels, 0
802.11a channels) [ 12.964761] Console: switching to colour frame
buffer device 160x50 [ 12.990478] fb0: radeondrmfb frame buffer
device [ 12.990481] drm: registered panic notifier [ 12.990492]
[drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 13.228016] intel8x0_measure_ac97_clock: measured 55365 usecs (2667
samples) [ 13.228022] intel8x0: clocking to 48000 [ 13.228862]
snd_intel8x0m 0000:00:1f.6: setting latency timer to 64 [ 14.398510]
cfg80211: World regulatory domain updated: [ 14.398518] cfg80211:
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 14.398522] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz),
(N/A, 2000 mBm) [ 14.398526] cfg80211: (2457000 KHz - 2482000 KHz @
40000 KHz), (N/A, 2000 mBm) [ 14.398530] cfg80211: (2474000 KHz -
2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 14.398534] cfg80211:
(5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 14.398538]
cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 14.398542] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz),
(N/A, 2000 mBm) [ 14.398546] cfg80211: (5735000 KHz - 5835000 KHz @
80000 KHz), (N/A, 2000 mBm) [ 14.398550] cfg80211: (57240000 KHz -
63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 15.917928] Adding
1633276k swap on /dev/sda5. Priority:-1 extents:1 across:1633276k
[ 15.933788] EXT4-fs (sda1): re-mounted. Opts: (null) [ 16.398238]
EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 16.527396]
loop: module loaded [ 17.745397] EXT4-fs (sda3): mounted filesystem
with ordered data mode. Opts: errors=remount-ro [ 19.066992] RPC:
Registered named UNIX socket transport module. [ 19.066996] RPC:
Registered udp transport module. [ 19.066999] RPC: Registered tcp
transport module. [ 19.067002] RPC: Registered tcp NFSv4.1
backchannel transport module. [ 19.130170] FS-Cache: Loaded
[ 19.185566] NFS: Registering the id_resolver key type [ 19.185600]
FS-Cache: Netfs 'nfs' registered for caching [ 19.219411] Installing
knfsd (copyright (C) 1996 okir@monad.swb.de). [ 21.653767] input:
ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 23.389851] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.389857] Bluetooth: BNEP filters: protocol multicast
[ 23.444152] Bluetooth: RFCOMM TTY layer initialized [ 23.444160]
Bluetooth: RFCOMM socket layer initialized [ 23.444163] Bluetooth:
RFCOMM ver 1.11 [ 23.521247] lp0: using parport0 (interrupt-driven).
[ 23.675955] ppdev: user-space parallel port driver [ 28.282559]
8139cp 0000:02:01.0: eth0: link down [ 28.282768]
ADDRCONF(NETDEV_UP): eth0: link is not ready [ 29.935267]
lib80211_crypt: registered algorithm 'CCMP' [ 30.176947]
lib80211_crypt: registered algorithm 'TKIP' [ 40.848012] eth1: no
IPv6 routers present [ 2953.376192] CCMP: decrypt failed:
STA=e4:6f:13:38:2c:b8 [ 2953.849207] ipw2200: Failed to send ASSOCIATE:
Already sending a command. [13985.713306] I-pipe: head domain RTAI
registered. [13985.713314] RTAI[hal]: compiled with gcc version 4.7.2
(Debian 4.7.2-5) . [13985.713323] RTAI[hal]: mounted (IPIPE-NOTHREADS,
IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[13985.713328] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6229750,
CLK_FREQ 1694459000, CPU_FREQ 1694459000 [13985.713332]
RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314;
LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [13985.713337]
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6229750, 6229750,
6212250 [13986.071579] RTAI[malloc]: global heap size = 2097152 bytes,
<BSD>. [13986.071640] , <uses LINUX SYSCALLs>, kstacks pool size =
524288 bytes. [13986.071646] RTAI[sched]: hard timer type/freq =
APIC/6229750(Hz); default timing: oneshot; linear timed lists.
[13986.071652] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq
= 1694459000 hz. [13986.071655] RTAI[sched]: timer setup = 999 ns,
resched latency = 2943 ns. [13986.245759] RTAI[math]: loaded.
[13989.734931] RTAI[math]: unloaded. [13989.737242] SCHED releases
registered named ALIEN PEDV$D [13989.744978] RTAI[malloc]: unloaded.
[13989.844018] RTAI[sched]: unloaded (forced hard/soft/hard
transitions: traps 0, syscalls 0). [13989.846126] I-pipe: head domain
RTAI unregistered. [13989.846139] RTAI[hal]: unmounted. [15338.678054]
I-pipe: head domain RTAI registered. [15338.678064] RTAI[hal]: compiled
with gcc version 4.7.2 (Debian 4.7.2-5) . [15338.678073] RTAI[hal]:
mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED),
ISOL_CPUS_MASK: 0). [15338.678078] SYSINFO: CPUs 1, LINUX APIC IRQ
2312, TIM_FREQ 6229750, CLK_FREQ 1694459000, CPU_FREQ 1694459000
[15338.678082] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314;
LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [15338.678087]
6212250 [15339.036266] RTAI[malloc]: global heap size = 2097152 bytes,
<BSD>. [15339.036311] , <uses LINUX SYSCALLs>, kstacks pool size =
524288 bytes. [15339.036318] RTAI[sched]: hard timer type/freq =
[15339.036323] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq
= 1694459000 hz. [15339.036327] RTAI[sched]: timer setup = 999 ns,
resched latency = 2943 ns. [15339.252703] RTAI[math]: loaded.
[15342.933914] RTAI[math]: unloaded. [15342.936271] SCHED releases
registered named ALIEN PEDV$D [15342.944288] RTAI[malloc]: unloaded.
[15343.044015] RTAI[sched]: unloaded (forced hard/soft/hard
transitions: traps 0, syscalls 0). [15343.046349] I-pipe: head domain
RTAI unregistered. [15343.046362] RTAI[hal]: unmounted.
Architecture: i386
linuxcnc.org
(>= 2.12.0) |
libglu1 |
libsm6 | 2:1.2.1-2
libtinfo5 | 5.9-10
| 2:1.1.1-1 libxss1 |
1:1.2.2-1 libxt6 |
tcl8.5 | 8.5.11-2
python2.7-tk 2
Last edit: 10 Nov 2016 08:36 by andypugh.
10 Nov 2016 08:37 #82639
Replied by andypugh on topic [Bug Report] Crash using Mach3 imported configuration
Not a solution to the problem, but I think that you won't see this if you un-select the box for "create simulator config" somewhere early-on on Stepconf.
Time to create page: 0.162 seconds
