× Forum Header
FAQ about the StepConf Wizard
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
21 May 2009 12:04 - 15 Feb 2016 11:51 #321 by BigJohnT
FAQ about the StepConf Wizard was created by BigJohnT
Does the Stepconf Wizard use doublestep?
Starting with 2.3.x stepconf looks at the timings and base_period involved, and it decides if it should generate a doublestep config or not, doublestep gives one step per period instead of one step every other period.
Can I import my Mach3 xml file into the StepConf Wizard?
Yes, starting in 2.7 the Stepconf Wizard can import a Mach3 configuration of up to 4 axes.
JT
Last edit: 15 Feb 2016 11:51 by BigJohnT.
The topic has been locked.
Time to create page: 0.144 seconds
