Forum Header
Light Machines Company Mill
28 Jul 2010 05:17 #3501
by rexhunt
Light Machines Company Mill was created by rexhunt
Here at school we have an old light machines comppany super spectra light mill that has a shady stepper. We also have a lathe by the same company that has been converted to a mill that I am planning to get a replacement stepper from. The only problem is the computer with the software on it doesnt work anymore, but I am trying to get emc to drive it...does anyone have any idea where i can find the pinout?
thanks
Rex
thanks
Rex
28 Jul 2010 06:12 - 28 Jul 2010 06:13 #3504
Replied by cmorley on topic Re:Light Machines Company Mill
Check this out:
www.cnczone.com/forums/showthread.php?t=108329
which will send you to here:
build.spaceopera.org/site/spectralight02...rtadapter/index.html
Last edit: 28 Jul 2010 06:13 by cmorley.
16 Aug 2010 03:14 #3770
by rexhunt
Replied by rexhunt on topic Re:Light Machines Company Mill
16 Aug 2010 03:15 #3771
by rexhunt
17 Aug 2010 21:37 - 17 Aug 2010 21:38 #3795
by shaworth
Replied by shaworth on topic Re:Light Machines Company Mill
Hello, I built and maintain build.spaceopera.org/ . The EMC configuration was incomplete, this was an oversight that has been fixed. The correct values can be found on the site under "EMC2 Configuration".
Cheers,
Shannon
Cheers,
Shannon
Last edit: 17 Aug 2010 21:38 by shaworth.
18 Aug 2010 03:05 #3797
by rexhunt
Ok thanks for that.
I will update as soon as there is any news
23 Aug 2010 01:07 #3846
by rexhunt
Ok I have now got it all set up to move as in your configuration, however the steppers make a lot of noises that sound like gears grinding in a manual gearbox and may move a little but will only move in one direction and will still make a whole heap of extra noise while moving...any ideas?
23 Aug 2010 10:08 #3851
by Rick G
Replied by Rick G on topic Re:Light Machines Company Mill
It sounds like you might be trying to drive the steppers too fast. Try making a drastic reduction in your velocity and adjusting your acceleration.
Rick G
Rick G
23 Aug 2010 21:58 #3856
by BigJohnT
Replied by BigJohnT on topic Re:Light Machines Company Mill
and or increase your step timing...
24 Aug 2010 23:00 - 24 Aug 2010 23:17 #3863
by rexhunt
ok I will try that and tell you how it goes
How much would I need to change the numbers by? Or would that be too machine specific to my machine?
Last edit: 24 Aug 2010 23:17 by rexhunt. Reason: Poor spelling
Time to create page: 0.181 seconds
