Configuring LinuxCNC
StepConf Wizard
Light Machines Company Mill
Thank you received: 306
18 Sep 2015 01:20 - 18 Sep 2015 01:20 #62723
by cncbasher
can you show a picture of the stepper drivers used , and perhaps any modle number or information on them
a lot of older stepper controllers are 12v TTL and require a buffered circuit .to work with a parallel port ( such as parker ) or a simple transistor collector input
also depends on the bob your using .
if they are new drives then as Andy mentions , you tie the + side of the opto's to 5v and the negative sides become the inputs from the parallel port
but show us the internals , and we may be able to work it out for you
StepConf Wizard
Time to create page: 0.107 seconds
