Forum Header
How to import a configuration from Emc2 2.3?
02 Aug 2018 09:43 #115389
by Havana7
How to import a configuration from Emc2 2.3? was created by Havana7
- Thank you received: 6006
02 Aug 2018 10:33 #115390
Replied by tommylight on topic How to import a configuration from Emc2 2.3?
The configs folder should do nicely if you do not have any special comps installed.
02 Aug 2018 10:37 #115392
by Havana7
Replied by Havana7 on topic How to import a configuration from Emc2 2.3?
Can I safely copy the folder to the new LinuxCnc 2.7 folder?
02 Aug 2018 11:15 #115395
Yes.
That is a config for a proxon, right? That is easy to set up even if you do not have the config.
03 Aug 2018 11:10 - 03 Aug 2018 11:10 #115499
Replied by andypugh on topic How to import a configuration from Emc2 2.3?
There are a few minor changes to be made when using a 2.3 config with 2.7.14
You only need to pay attention to the _configuration_ changes on these pages, ignore the actual upgrade instructions.
<nothing to do for 2.3 to 2.4>
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.5
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
linuxcnc.org/docs/2.7/html/getting-start..._configuration_files
You can just try running your existing configs and correct the errors one by one.
Last edit: 03 Aug 2018 11:10 by andypugh.
Time to create page: 0.249 seconds
