Forum Header
StepConf Test Axis vs Axis
20 Sep 2018 20:46 #117821
by riversvic
StepConf Test Axis vs Axis was created by riversvic
When I set up and test axis in stepconf the amount of total travel is correct of half an inch. In axis when running and jogging everything is half the scale. What am I doing wrong?
20 Sep 2018 22:10 #117830
by riversvic
Replied by riversvic on topic StepConf Test Axis vs Axis
I changed my Driver microstepping to 4. Makes sense since the driver was set to 800 per rev. The only thing I can figure is that for some reason in StepConf when you run a range of half an inch that half inch both directions?
21 Sep 2018 01:26 #117833
by curtisa
Replied by curtisa on topic StepConf Test Axis vs Axis
The 'Test Area' function in StepConf Wizard defaults to a plus/minus value, so setting it to 0.5in will run the axis -0.5in to +0.5in either side of its starting position. Ie 1in of total travel.
It can also be configured to run as separate '+' or '-' tests, in which case it should advance in the positive and negative directions by the amount specified.
Time to create page: 0.549 seconds
