× Forum Header
simulation mode
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
01 Apr 2022 23:42 #239036 by andypugh
Replied by andypugh on topic simulation mode
As you spotted, the problem now seems to be a segmentation fault. Which seems unexpected.
Do you get a segfault with the Axis interface too?
02 Apr 2022 02:03 #239039 by phillc54
Replied by phillc54 on topic simulation mode
The segfault is possibly caused by python3-espeak during shut down, it is probably not the cause of your issue.
AFAIK there has been no success in getting the QTvcp based GUIs working on a Pi with python3 due to the way the python3-opengl module is built. It is posible this may have been fixed recently but not that I am aware of.
02 Apr 2022 02:31 - 02 Apr 2022 02:42 #239041 by ajsinfotech
Replied by ajsinfotech on topic simulation mode
yes
Last edit: 02 Apr 2022 02:42 by ajsinfotech.
02 Apr 2022 02:34 #239042 by ajsinfotech
Hi phillc54, thanks for getting involved!
Do you mean if I point python interpreter to version 2 it could work ok?
02 Apr 2022 03:00 #239045 by phillc54
LinuxCNC 2.9 is python3 only, for python2 you need to use LinuxCNC 2.8 but I believe the same issue also affects python-opengl which is the python2 version.
Seeing as how you get a segfault when using Axis there must be something else in play as well.
06 Apr 2022 17:16 - 06 Apr 2022 17:31 #239456 by ajsinfotech
Hi dear,
Finally I tried to do a brand new installation version 2.9 on a RPi4.
Now when I throw this command:
./configure --with-realtime=uspace
I get this:
checking for python pango module... Traceback (most recent call last):
  File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'gi'
no
configure: error: Python pango module not found!
install with "sudo apt-get install python3-gi"
The python3-gi module seems to be already installed. Anyway, I removed and intalled it again but always the same.
I was googling about python3-gi but there is not much info about it.
Does LinuxCNC work on a RPi4?
Is there any recommended snapshot to download for RPi4?
Thanks!
Last edit: 06 Apr 2022 17:31 by ajsinfotech.
06 Apr 2022 18:41 - 06 Apr 2022 18:44 #239460 by ajsinfotech
Hi dear,
I also tried to do a brand new installation version 2.8 on a RPi4 (pointing to python2).
But when I compile, it throws the following error:
Compiling hal/user_comps/shuttle.c
Compiling hal/user_comps/xhc-hb04.cc
Compiling hal/user_comps/sendkeys.c
Compiling hal/user_comps/vfs11_vfd/vfs11_vfd.c
  File "/usr/bin/yapps2", line 6, in <module>
    from pkg_resources import load_entry_point
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3243, in <module>
    def _initialize_master_working_set():
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3226, in _call_aside
    f(*args, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set
    working_set = WorkingSet._build_master()
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 568, in _build_master
    ws.require(__requires__)
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 886, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/usr/local/lib/python3.10/site-packages/pkg_resources/__init__.py", line 772, in resolve
    raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'Yapps2==2.2.1' distribution was not found and is required by the application
make: *** [hal/utils/Submakefile:102: objects/hal/utils/halcompile.py] Error 1
make: *** Waiting for unfinished jobs....
Again, the module yapps 2.2.1 seems to be installed. I tried to reinstall it but no luck.
Thanks!
Last edit: 06 Apr 2022 18:44 by ajsinfotech.
07 Apr 2022 08:10 #239517 by rodw
Replied by rodw on topic simulation mode
If you go back to the linuxcnc docs and look at the Developer /Building linuxcnc, there is a heading about checking build dependencies. Follow that.
Copy the dependencies from the terminal into a text editor and edit to remove stuff in brackets or include the | symbol which says remove one or the other package.
then in a terminal window type "sudo apt install " then past the text back into the command..
I have installed Debian Bullseye on a Pi4B and compiled from source..
09 Apr 2022 18:54 #239768 by ajsinfotech
Hi rodw, thanks for join us!
I always play around this 2 installing methods:
1 - Building LinuxCNC
linuxcnc.org/docs/stable/html/code/building-linuxcnc.html
2 - Building LinuxCNC Uspace
gnipsel.com/linuxcnc/uspace/index.html
Now I found this trying to run QtDragon in sim mode:
/home/pi/linuxcnc/scripts/linuxcnc: line 963:  1875 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
The problem is IMHO, some kind of internal or advance configuration seems not to work:
So, digging deep in my /home/pi/linuxcnc/scripts/linuxcnc around line 963 I have the following:
# 4.3.11. Run display in foreground
echo "Starting DISPLAY program: $EMCDISPLAY" >>$PRINT_FILE
result=0
case $EMCDISPLAY in        <== *** THIS IS LINE 963 ON LINUXCNC SCRIPT ***
  tklinuxcnc)
    # tklinuxcnc is in the tcl directory, not the bin directory
    if [ ! -x $LINUXCNC_TCL_DIR/$EMCDISPLAY.tcl ] ; then
    echo "Can't execute DISPLAY program $LINUXCNC_TCL_DIR/$EMCDISPLAY.tcl $EMCDISPLAYARGS"
    Cleanup
    exit 1
    fi
    $LINUXCNC_TCL_DIR/$EMCDISPLAY.tcl -ini "$INIFILE" $EMCDISPLAYARGS
    result=$?
So, what is $EMCDISPLAY? Its value seems to be wrong.
What value does it need and where do I have to set it up?
Any idea is welcome!
Thanks!
09 Apr 2022 20:17 #239770 by rodw
I rarely play with the Pi but I think the current version of the pi operating system is based on Debian Bullseye which does not include python3
If you are using the Linuxcnc iso for the pi, you would need to go the src folder and type:
checkout 2.8
before trying to build it
Hopefully this will align the dependendencies with what you have, But you will still need to resolve them as discussed above.
Time to create page: 0.256 seconds
