Forum Header
Why two configuration files?
12 Nov 2018 10:20 #120478
by gimpo
Why two configuration files? was created by gimpo
Just a stupid question: why there are two different configuration files with linuxcnc?
I mean... after running the StepConf Wizard I get a blablabla.conf file. Nevertheless, when I run linuxcnc I use the command linuxcnc /folder/blablabla.ini.
Why?
Also, not all options/parameters are listed in the .ini file. To get the complete configuration one has to look at the .conf file.
Why?
12 Nov 2018 10:40 #120480
Replied by cmorley on topic Why two configuration files?
The. .conf file is made by stepconf so you can reload all your stepconf choices.
The INI file is used by linuxcnc.
Chris M
Chris M
12 Nov 2018 11:19 #120483
by gimpo
Replied by gimpo on topic Why two configuration files?
Axis parameters like steps-per-revolution, screw-lead-pitch, micro-steps are not listed in the .ini file. From where linuxcnc pick those values???
12 Nov 2018 11:49 #120485
linuxcnc doesn't need this information, it uses the completed equation of these setting - the SCALE
Chris
Chris
12 Nov 2018 12:13 #120486
by gimpo
Uh!...
Nice!
Nice!
Time to create page: 0.205 seconds
