Forum Header
spindle speed backwards?
- tonydiethelm
30 Dec 2018 06:45 - 02 Jan 2019 06:21 #123135
by tonydiethelm
spindle speed backwards? was created by tonydiethelm
Edit: This was solved by inverting the Spindle PWM pin. No idea WHY that worked, as the output is a PWM signal to create an analog voltage, but... a'ight... working is working.
NOW I'm having problems with setting up the scaling. I really only need 0-2.5V on the output for my speed control. I'm setting up PWM1 to 0 and PWM2 to 0.25... but then I get nothing on the output, whereas I WAS getting 0-10V output with a test case.
Hello!
First... Thanks for LinuxCNC! I've been using it for years on homebrew machines.
I finally got around to getting a spindle instead of a router.
I wanted to test generic voltages out on my breakout board for spindle speed control. My spindle just needs an analog voltage for speed control. Cool. So...
I set speed 1 to 0, PWM 1 to 0.
I set speed 2 to 1000, PWM2 to 1.
Just like the documentation said to do.
S500, measures about 5v out on my breakout board, which should go 0-10v. Great!
When I increase the speed (s500, s600, s700) the voltage is going.... down?
When I decrease the speed (s400, s300, s200) the voltage is going up.
I am under the impression that this is supposed to be the other way around? Low voltage, low speed, high voltage, high speed.
What am I missing?
just for shitsngiggles, I reversed the order, trying to go from PWM1 of 1 to PWM2 of 0. That didn't work...
PWM rate is set to 100Hz, per documentation for the board.
Hello!
What am I missing?
Last edit: 02 Jan 2019 06:21 by tonydiethelm. Reason: solved, editing to say so.
- Mike_Eitel
- Thank you received: 185
31 Dec 2018 10:28 #123195
by Mike_Eitel
Replied by Mike_Eitel on topic spindle speed backwards?
Easiest way.
SUM2 with negative maxvalue inverts inputvalue
Mike
Mike
- tonydiethelm
01 Jan 2019 06:02 #123251
by tonydiethelm
Replied by tonydiethelm on topic spindle speed backwards?
Uhh.... Can you... give just the slightest bit more context?
- Mike_Eitel
01 Jan 2019 10:06 #123256
by Mike_Eitel
Take your commanded value ( before input into probably into pwmgen.x.value) as input for
Setp sum2.x.in0 - 1
Setp mult2.x.in0 - 1
Net xxx1name (your signal) -> sum2.x.in1
Net xxx2name sum2.x.out -> mult2.x. in1
Net xxx3name mult2.x.out -> pwmgen.x.value
Mike
Setp sum2.x.in0 - 1
Mike
- tonydiethelm
02 Jan 2019 03:37 #123303
by tonydiethelm
Andypugh suggested "Try inverting the PWM pin".
That worked... heh. Thanks though!
Time to create page: 0.331 seconds
