Forum Header
spindle speed configuration question
- tonydiethelm
30 Dec 2018 20:56 #123170
by tonydiethelm
spindle speed configuration question was created by tonydiethelm
Hi all,
I just moved to a spindle after years of using LinuxCNC with a trim router.
Everything seems fairly straighforward, but.....
I'm trying to get PWM to work with my breakout board and .... well...
I set up the basic config, as per the documentation.
speed 1 is 0, PWM 1 is 0
speed 2 is 1000, PWM 2 is 1
If I'm understanding this correctly, this should allow me to go up in speed (S100, S200.... S800, S900) and basically change the analog voltage at my breakout board from 0-10V (My breakout board goes from 0-10V).
And it does... sorta...
It goes backwards! S500 is 5V. S200 is 8V, S800 is 2V. WHY?
31 Dec 2018 14:16 #123206
Replied by andypugh on topic spindle speed configuration question
Try inverting the PWM pin. Maybe the BoB expects active-low?
- tonydiethelm
02 Jan 2019 03:38 #123304
by tonydiethelm
Replied by tonydiethelm on topic spindle speed configuration question
That totally worked. No idea WHY, since this is supposed to be a PWM wave and it really shouldn't matter, but... fuck it, it works.
Thanks!
Thanks!
04 Jan 2019 13:11 #123470
PWM is inverted if the pin polarity is changed.
100% is either constant 5V or 0V, and then 0% is, respectively, 0V or 5V.
At 50% it doesn't matter
06 Jan 2019 13:20 #123600
by pl7i92
Replied by pl7i92 on topic spindle speed configuration question
this is for 5axis China mach boards they are activ low designed
and also expect that on the Step dir inputs
Time to create page: 0.178 seconds
