Forum Header
mesa 5i25/7i77 Yaskawa servo
- Thank you received: 1370
12 Aug 2019 13:10 #141965
Replied by Todd Zuercher on topic mesa 5i25/7i77 Yaskawa servo
If MAX_OUTPUT is set to 0.0 then it is probably ignored, the same as if no MAX_OUTPUT is specified.
The following user(s) said Thank You: IanK
24 Aug 2019 05:05 #143055
by IanK
Replied by IanK on topic mesa 5i25/7i77 Yaskawa servo
Thanks Guys,
We seem to have the basics all sorted now. Runs smoothly, the DRO agrees with the ruler using 500 counts per unit.
A question about setting up axis. The machine has 6 over-limit safety switches that we have left as was, ie. operating the relay holding power to the servo drivers. The 3 homing switches, acting comfortably inside the over-limit switches, are now handled via the 7i77. Homing is making the right sort of moves but at what the DRO sees as the positive ends of the axis. Either way, the homing switches on this old machine appear to have originally been set up for a left handed axis system!
I assume you can set it up anyway you like, but is there a preferred standard in use by machinists that it's worth conforming to? i.e. a right handed system. The z axis I'm thinking should be positive in the up direction, but homed at the top, with deeper cuts being more negative numbers? Should X and Y then be made to follow as a right handed system, zeroed at the negative end such that the table is traversed with positive co-ordinates?
To get the PID working with the drive direction we needed to set output scale to -10 in the ini file. I understand that this is also the way to reverse direction of the axis. Would this mean having P and FF1 as negative numbers? Is this normally how it's done or is there a tidier way of doing it? I suspect we could also reverse the hardware connections of our encoder but I would rather leave that conforming with the circuit diagrams of the manuals you find in the internet. ( You don't want to make the system too illogical for anybody following behind. Morbidelli's not perfect at that either!)
Thanks again
Cheers Ian
Thanks again
Cheers Ian
24 Aug 2019 05:44 #143056
Replied by PCW on topic mesa 5i25/7i77 Yaskawa servo
Its best to reverse the analog output scale (as you have done)
to correct backwards feedback.
Swapping encoder leads will reverse the feedback position which
is not what you want if its already correct
I would not use negative PID parameters, there are bugs in the PID component with negative parameters
24 Aug 2019 06:50 - 24 Aug 2019 06:52 #143057
by IanK
Thanks Guys,
Thanks again
Cheers Ian
Thanks again
Cheers Ian
Last edit: 24 Aug 2019 06:52 by IanK. Reason: post doubled up. just want to delete the repeat.
- Thank you received: 5983
24 Aug 2019 09:13 #143071
Replied by tommylight on topic mesa 5i25/7i77 Yaskawa servo
You can set homing anyway you like it or need it, there are plenty of settings for that like especialy if you have limit/home switches at both ends of the travel, like:
Home_search_velocity set to negative value if you want it to home at the oposite side of the table. You might also need to reverse latch and end move velocity to fit your setup.
Set the home at the other side of the table ( if you have 300mm travel, set home to 300 or -300 ), this will search for the switch in one direction, find it, then travel to the other side of the table and set home there.
Z should always home up and search up and that should be the positive side, as you mentioned above.
25 Aug 2019 00:28 #143114
by IanK
Thanks Tommy,
Sometimes the obvious eludes you. Yes home switches at one end but run to the other end of the table for home itself.
Still can't see the easiest way to change from a LH to RH axis orientation. I'm stuck at either physically reversing the output of one of the 3 encoders or switching the axis naming such that X is across the bed (along the gantry) and Y is the longest axis. Is there a convention here we should stick to?
25 Aug 2019 01:29 #143115
Replied by rodw on topic mesa 5i25/7i77 Yaskawa servo
What version of Linuxcnc are you running? Your link was to V 2.6 which may be different to later versions. For the important stuff, always start at them main linuxcnc site and follow the links to the docs for your version.
I know setting this stuff up does your head in. It did to me when I built my machine.
I think there is a scale pin on the Mesa encoder inputs which you can change the sign of to reverse the direction but I only ever use the encoder input for plasma torch voltage.
I've only ever used V2.8 and V2.9 but have set up my machine either way (eg gantry has been set as X or Y at different times) and the homing is different to 2.7. I've also reversed the direction of the Z axis at different times. All in software.
and yes, if it homes to the max limit end, you could apply a home offset to move it back to the correct position.
Also with Z axis direction, I found it was easiest to apply a permanent G54 offset. eg my Z axis is 86mm long so I go to the top of the axis and touch off at +86mm which puts the bottom of travel at 0.0. Linuxcnc remembers this so it should never need touching again. But with plasma I don't ever need to control the Z axis from gcode.
25 Aug 2019 09:02 #143124
Wait, is the direction of moving correct ?
If it is not, just add a - in front of scale or encoder scale.
If homing is in the wrong direction add a - to home search velocity.
27 Aug 2019 11:21 #143313
by IanK
Thanks Rod, Thanks Tommy,
We have version 2.7 running. I'll make sure I search in that version.
So it appears there's no particular standard re left or right handed axis setup. Goes for driving on Australian vs. Italian roads I suppose I shouldn't have expected the hardware layout of the Morbidelli to offer any clues. But now knowing that we can easily convert orientation in software takes it away as a potential future problem.
We should note that to reverse the axis direction you need to flip the sign of both the encoder-scale and the output-scale in the ini file. Switching just one of them will have the PID output acting in the positive feedback direction and you'll immediately get a max-f-error shutdown.
Cheers Ian
Cheers Ian
27 Aug 2019 11:39 #143316
Wait, you mean Australia vs the rest of the world, besides England and Japan, and Japan is undecided ! ? ! ?
Sorry for forgeting to mention that both values need to be changed, to much of everything lately.
Time to create page: 0.269 seconds
