Forum Header
cnc 5 axis
09 Feb 2019 03:41 #126031
by gois
cnc 5 axis was created by gois
Hello!
I need to configure the 5th axis of a cnc router, it would be possible for someone to explain to me how to do or pass the configuration files
09 Feb 2019 11:52 #126049
by pl7i92
Replied by pl7i92 on topic cnc 5 axis
Hi
You need to post Your setup or mashine Layout
to see How Axes go together
There is a different between
XYZ AC
XZ YAC
you might get a Search on TCP Linuxcnc
ToolCenterPosition
This gives you more Flexibility
XYZ AC
XZ YAC
ToolCenterPosition
10 Feb 2019 20:32 - 10 Feb 2019 20:33 #126172
by gois
Replied by gois on topic cnc 5 axis
Do you want the following?
X Y Z linear movement
A B Rotary axes.
I need to know how to configure the B axis since in wizardd config step the 5th axis does not appear.
A B Rotary axes.
Last edit: 10 Feb 2019 20:33 by gois.
Time to create page: 0.080 seconds
