Forum Header
back down the stepper timing rabbit hole....
12 Feb 2019 17:24 #126285
by IrishMoss
back down the stepper timing rabbit hole.... was created by IrishMoss
So after a long break away from the CNC for other obligations, I finally got back to it recently and got it up and running and even doing a few test jobs... well almost.
Seems it's occasionally missing a step or 2. Which I expected to need some tweaking. So now I'm knee deep in about 27 open browser windows.
Anyway, I'm going back over my stepper config numbers, and following the info here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Tweaki...ftwareStepGeneration
I've used the calc spreadsheet in the bottom of that doc, and it's giving these post-test numbers:
stepgen.steplen 1 periods
stepgen.stepspace 1 periods
stepgen.dirsetup 2 periods
stepgen.dirhold 2 periods
I'm confused as to how to set these 'period' values. Checking the docs, it seems like all these are supposed to have settings of nanoseconds.
Also, in that stepper tweaking doc it mentions "So we change dirhold from 1 to 2" in an example. But it's not entirely clear where/how this is set.
Where are these 'period' values set, as opposed to the nanosecond values?
Thanks.
Thanks.
12 Feb 2019 17:27 #126286
Replied by PCW on topic back down the stepper timing rabbit hole....
That wiki information is very out of date
I would just use a current linuxcnc's stepconf program to set the values in nanoseconds
12 Feb 2019 18:54 #126290
by IrishMoss
Is there anything else I should be concerned with? or just focus on fiddling with those?
Replied by IrishMoss on topic back down the stepper timing rabbit hole....
So basically keep all the tweaking to the dirhold and dirsetup values?That wiki information is very out of date
12 Feb 2019 19:15 - 12 Feb 2019 19:15 #126291
Not sure you you would spend any time tweaking the setup and hold times.
Just set them to 20000 ns and be done with it, there is basically 0 cost to making
these larger than needed and 20000 ns will work for almost any drive.
Last edit: 12 Feb 2019 19:15 by PCW.
12 Feb 2019 19:34 #126292
by IrishMoss
Not sure how much of what I've been reading is outdated, but I was under the impression that the higher these are set, the less steps per second, which could result in performance issues. But if it's not a big deal, I won't sweat it.
well, I'm off the shop to make some changes and run another test.
wow, ok... color me confused.Not sure you you would spend any time tweaking the setup and hold times.
12 Feb 2019 19:43 - 12 Feb 2019 19:46 #126293
The setup and hold time settings have basically zero effect on performance
The steplen and stepspace settings _do_ set a bound on the maximum step rate: MaxStepRate = 1/(steplen+stepspace), though typically the maximum step rate is bound by the latency in software stepping (parallel port) configurations.
Also if you use the stepgen's reset feature (which allows 1 step per base thread invocation instead of every other invocation),
the length of the step pulse affects CPU load since LinuxCNC does a busy loop waiting for this to time out.
Last edit: 12 Feb 2019 19:46 by PCW.
13 Feb 2019 01:33 #126320
by IrishMoss
Thanks PCW!
Based on recommendations for my controllers, I initially had dirhold=10000 and dirsetup=5000. I doubled those, ran another test run, and no missed steps! (well, at least not that i could tell)
I do have a small accuracy issue on the X axis, but I'm pretty sure that's hardware related (otherwise i'd expect to see it on all axes)
I'm also going to look into that 'stepgen reset' you mentioned. Not sure I'll need it now, but who knows.
Thanks again!
Thanks again!
Time to create page: 0.083 seconds
