Forum Header
Newbie in need of help
15 Feb 2019 18:17 #126576
by JackB1
Newbie in need of help was created by JackB1
This everything I've done and all the settings. LinuxCNC Ver. 2.7.14
Stepconf Wizard settings as follows.
Base Information
Machine Name: Grand-Pa_Prb_Estp_V1.3
Configuration Dir: ~/linuxcnc/configs/Grand-Pa_Prb_Estp_V1.3
Axis Config: XYZ
Machine Units: Inch
Driver Type = Other
Step Time = 6000 ns
Step Space = 6000 ns
Direct. Hold = 5000 ns
Direct. Setup = 5000 ns
One Parport: *
Base per Max Jit: 15000 ns
Min Base Period: 21000 ns
Max step rate: 23809 Hz
Parallel Port 1
Outputs Inv. Inputs Inv.
Pin 1 = ESTOP Out Pin 10 = Unused
Pin 2 = x step Pin 11 = Unused
Pin 3 = x dir Pin 12 = Unused
Pin 4 = y step Pin 13 = ESTOP in
Pin 5 = y dir Pin 15 = Probe in
Pin 6 = z step
Pin 7 = z dir
Pin 8 = Unused Parport Base Address = 0
Pin 9 = Unused Output pinout presets = Sherline
Pin 14 = Spindle CW X
Pin 16 = Unused
Pin 17 = Unused
Options
Include Halui = checked include custom PyVCP = checked
Onscreen prompt for manual tool change = checked
Axis X, Y & Z
Motor steps per revolution: 200
Driver Microstepping: 16 (X, Y & Z set to same)
Pulley teeth: 1: 1 (X, Y & Z set to same) (Direct Drive)
Leadscrew Pitch: 20 rev/in
Maximum Velocity: 1.0 in / s
Maximum Acceleration: 20.0 in / s²
Home Location: 0
Table Travel: 0 to 8 = X, 0 to 5.0 = Y, Z = -4.0 to 2.0
Home switch location: 0 for all Axis (Not used yet)
Home search velocity: 0.05 for all
Home latch direction: Same used for all axis
Time to accelerate to max speed: 0.0500 s
Distance to accelerate to max speed: 0.0250 in
Pulse rate at max speed: 64000 hz
Axis scale: 64000.0 Steps / in
200 x 16 x (1.0 ÷1.0) x 20.000 =
Test this axis
Velocity: .07 in /s
Acceleration: 20.0 in /s²
Left and Right jog works Excellent.
Test area also works as it should.
I’m using the Chinese Blue 5-axis controller from Sain Smart. And the MD430-V1.4 stepper driver boards with the following settings. Which work awesome when running the “Test this Axis”.
SW 1 = 1, SW 2 = 1, SW 3 = 0 for current of 2.0(A)
S1 = 0, S2 = 1 Decay mode of 50⁒
S3 = 0, S4 = 1 Excitation mode of 16 microsteps
S5 = 1, S6 = 0 Torque settings of 75⁒
With all this done in Stepconf. And with the mill responding during the “Test this Axis” for each axis. When I run the Launcher, start the machine and run the LinuxCNC default G-Code. The Axis screen shows it following the G-Code as it should. But, now NONE of the steppers on the mill are moving at all.
Thank you,
Jack “I’m stuck on this one” Burnsworth
Base Information
Axis Config: XYZ
Machine Units: Inch
Driver Type = Other
Step Time = 6000 ns
One Parport: *
Parallel Port 1
Pin 6 = z step
Pin 7 = z dir
Pin 16 = Unused
Pin 17 = Unused
Options
Axis X, Y & Z
Home Location: 0
Test this axis
Velocity: .07 in /s
Thank you,
16 Feb 2019 16:56 #126610
by pl7i92
Replied by pl7i92 on topic Newbie in need of help
Hi
The AXIs TEST does pull all pins not related to STEP DIR High
maybe your ESTOP Routine pins arent correct set
What Controller interface is it
PLEASE Join the Live Help Channel on the IRC
use HEXCHAT
and connect to freenode
in the entry line
/join #linuxcnc
use HEXCHAT
in the entry line
/join #linuxcnc
Time to create page: 0.144 seconds
