Forum Header
gmoccappy and stepconf wizard's files
06 Mar 2019 19:07 #127905
by celalcnc
gmoccappy and stepconf wizard's files was created by celalcnc
Stepconf wizard creates ini and hal file for only axis. I use parallel port for interfacing motor drivers. Can we rearrange stepconf wizard ini file for gmoccapy and hal file for parallel port?
Thanks in advance who reply this post.
06 Mar 2019 20:26 - 06 Mar 2019 20:36 #127908
by Leon82
Replied by Leon82 on topic gmoccappy and stepconf wizard's files
You can pick GMOCCAPY from the step config wizard
Edit to add, on 2.8
In the ini all you have to do is replace the word axis with GMOCCAPY where it says display
Edit to add, on 2.8
Last edit: 06 Mar 2019 20:36 by Leon82.
07 Mar 2019 07:56 #127958
by pl7i92
Replied by pl7i92 on topic gmoccappy and stepconf wizard's files
yiu may now STEP into PRO USER and
TAKE Editor"gedit" and edit one LINE by HAND
DISPLAY = axis
DISPLAY = gmoccappy
IF there is a PYVCP panel plese unmark it with #
also the postgui HAL of the panel and you are up
DISPLAY = axis
DISPLAY = gmoccappy
The following user(s) said Thank You: celalcnc
Time to create page: 0.167 seconds
