Forum Header
jog speed
09 Mar 2019 08:36 #128140
by deslee848
hi,need some help,why the jog speed is difference from the machine speed.the machine speed looks slow compare to the jog speed.because the jog speed come out with a # of 9000mm/min.i know my machine only can run about 3000mm/min.can some one let me know where is the setting.thanks
09 Mar 2019 08:46 #128143
by pl7i92
there is all ok in the ini file
you shoudt keep the BASE Period at 100000 / 100k at below 200mm/sec
FOR safty reason enofh stepspace
DID you cut the max speed Slider
Almost Down in AXIS to the max
and the top Slider to 100 Percent
WEAR Behavior
Did you start with a frech stepconf or did you copy over to a new system
What is the System you use
Wheezy 2.7.14 recomended
Uspace 2.8 ???
WEAR Behavior
Uspace 2.8 ???
09 Mar 2019 11:38 #128154
by pl7i92
it is also not clear what he likes to say mashine speed
in G-code run or display
if all are set to 170 beside Z axis is 76 it shoudt run also the mashine without z move
if you get low speed at sculping or like woodwork plasma ...
you may ad a G64 P.2 to the G-code
this also can be a sign of to low steps between next point in order 0,1mm as the interpreter does only read up to 3-10 lines ahead
meaning it gets its next stop at iinternal below retching max speed rate
09 Mar 2019 13:41 #128162
by MaHa
The scale of the Axis_ looks a bit strange, (the steps needed including microsteps for a move of 1mm). Could be the slow machine movement. Recalculate to confirm the entrys.
Set all MAX_LINEAR_VELOCITY and MAX_VELOCITY to 50
Or wait for advice from other specialist.
10 Mar 2019 05:51 #128201
by deslee848
hi,thanks for the prompt replies.i think you misunderstand my question.or maybe i dont know how to express what i want to say.
actually my question is:
driver DM542
Nema 23 steepermotor
input voltage,36v
using lcnc 14
can it be running at 9000mm/min or higher?
because i saw the jog speed are9000mm/min topspeed ,but the table movement give me the impression is slower,it seem that it did not match 9000mm/min!So where can set it to match it both.thank you.
driver DM542
input voltage,36v
using lcnc 14
10 Mar 2019 08:08 - 10 Mar 2019 08:13 #128207
by pl7i92
the max Velocity is up to your mashine setup and hardware
the m542 shoudt go beond 12m/min at 100steps/mm meaning 0,01per step
at 36V it is not the best PRESSURE better to go for 48V to get faster steprate
the Latency of your PC is also to considder
change MAX_LINEAR_VELOCITY = 150.00
to
MAX_LINEAR_VELOCITY = 200.00
and try this ini
to
and try this ini
[EMC]
MACHINE = my-mill_start
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 5mm 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 15.00
MIN_LINEAR_VELOCITY = 0
INTRO_TIME = 5
PROGRAM_PREFIX = /home/deslee/linuxcnc/nc_files
INCREMENTS = 1mm .5mm .1mm .05mm .01mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = my-mill_start.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 15.00
MAX_VELOCITY = 200.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_ACCELERATION = 250.0
STEPGEN_MAXACCEL = 275.0
SCALE = 33.3333333333
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1500.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 11.1111111111
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1000.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 76.0009052217
MAX_ACCELERATION = 100.0
STEPGEN_MAXACCEL = 125.0
SCALE = 198.511166253
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
Last edit: 10 Mar 2019 08:13 by pl7i92. Reason: ini edit
