Forum Header
Two parallel ports
30 Apr 2019 16:07 #132358
by gois
Two parallel ports was created by gois
Formerly on EMC2 you had the option to choose in the "Step wizard conf" the option of using two parallel cards.
Today I need to use two parallel cards and this option does not appear in the Linux CNC wizard.
I have the second card with address "0xe010" and pin 17 is a thread that I want to activate using an MDI command can someone help me how?
30 Apr 2019 17:24 - 30 Apr 2019 17:48 #132361
by Clive S
I have just checked and it is in steconf on the base page at the bottom. 2.7.14 and 2.8
Replied by Clive S on topic Two parallel ports
Last edit: 30 Apr 2019 17:48 by Clive S.
02 May 2019 05:57 #132488
by pl7i92
Replied by pl7i92 on topic Two parallel ports
you just need to enter bothe adresses in the first entry line
EXAMPLE
0x378 0xe010
thats all
the configuration is the same at it will show 2 parports in stepconf wizard
EXAMPLE
0x378 0xe010
thats all
24 Jun 2023 09:04 #274166
by masawee
Replied by masawee on topic Two parallel ports
why need use 0xe010 because all paraller ports use
LPT1: 0x378 (or occasionally 0x3BC) (IRQ 7)
LPT2: 0x278 (IRQ 6)
second port need be 0x278 not other i think.
3th port addres have LPT3: 0x3BC (IRQ 5)
all other addres not working not have.
LPT2: 0x278 (IRQ 6)
Time to create page: 0.098 seconds
