Forum Header
MESA 7i76 - Generate a given number of pulses.
- HalaszAttila
- Thank you received: 5
14 May 2019 11:02 #133724
by HalaszAttila
MESA 7i76 - Generate a given number of pulses. was created by HalaszAttila
Hello,
i use MESA 7i76 card, and my tool changer is rotated by stepper motor. What is the easiest way to generate with stepgen a given number of pulses?
Pulses between two tools in magazin is 4000 steps. I will combine with carousel component and just send N * 4000 impulse to the stepper to rotate the magazin.
Best regards,
A.
Best regards,
A.
14 May 2019 13:23 #133745
Replied by PCW on topic MESA 7i76 - Generate a given number of pulses.
Probably easiest thing would be to set the scale of the tool changer to 4000
so a position change of 1.0 = 4000 steps = 1 tool
The following user(s) said Thank You: HalaszAttila
Time to create page: 0.111 seconds
