Forum Header
Linuxcnc - plasma router - joint 2 flolowing error
16 Oct 2019 16:51 - 16 Oct 2019 16:58 #148009
by kofaki
Replied by kofaki on topic Linuxcnc - plasma router - joint 2 flolowing error
]Hello Tommy,
I didn't have time previously to continue building the plasma.
...Today I had a free day, i created a video with the error "joint 2 on limit switch error" . This error is loaded if drive axis Y.
Do you have any ideas, what is the fails ?
Many thanks,
Many thanks,
Last edit: 16 Oct 2019 16:58 by kofaki.
16 Oct 2019 17:01 - 16 Oct 2019 17:02 #148010
Replied by PCW on topic Linuxcnc - plasma router - joint 2 flolowing error
Possible reasons:
Limit switch broken
Limit switch polarity wrong
Limit switch wiring wrong
Noise on limit switch input
Wrong HOME_OFFSET or other homing settings in your .ini file
I would check the first three by monitoring the limit switch pin when doing a manual limit switch actuation
A noise problem will typically show up randomly (random places) or when some noisy device is activated
Posting your ini and hal files would allow forum members to see if your homing setup is correct
Limit switch broken
Last edit: 16 Oct 2019 17:02 by PCW.
- Thank you received: 5944
16 Oct 2019 17:22 #148018
Replied by tommylight on topic Linuxcnc - plasma router - joint 2 flolowing error
As PCW said, check all that and please do attach the ziped config folder here so we can look at it.
23 Oct 2019 22:34 #148639
Replied by andypugh on topic Linuxcnc - plasma router - joint 2 flolowing error
Joint 2 is Z. It sounds like there is some vibration, perhaps that is triggering the switch?
24 Oct 2019 05:43 #148671
by kofaki
Hello,
i replaced the cable for the float switch (new shielded cable) and the problem is the same ... As the control board i use
Config is in the attachment
Many thanks
Many thanks
27 Oct 2019 23:36 #148941
If you disconnect the Z limit switch in HAL (you can do this from the command line, once the system is homed) does that solve the problem?
halcmd unlinkp joint.2.pos-lim-sw-in
halcmd unlinkp joint.2.neg-lim-sw-in
They will re-connect if you exit and restart the config.
28 Oct 2019 14:57 #148980
by kofaki
Hello Andypugh,
yeah, that's works if is send the commands from your post.
it's Interesting, that i move with axisY, and the Z float switch is actived in LinuxCNC.
Now i tried the PROMA THC 150 module, but if i run the test on the module, then i see on LinuxCNC active LEDs (move UP and move DOWN) but the motor on axis Z nothing (stopped)
28 Oct 2019 15:27 #148983
OK, that means that it is noise on that signal.
The answer is probably to debounce the signal in HAL.
Is the man page link enough, or do you need more info?
linuxcnc.org/docs/2.8/html/man/man9/debounce.9.html
Hello Andypugh,
29 Oct 2019 14:25 #149050
by kofaki
NOTE: i don't use limit switches, only floating switch for find the position of material on Z axis.
Yes, could you please send me more info about debounce the signal in HAL ?
I use the control board with the DIGITAL INPUT, which are switching the signal to 12V, not to ground, then i want try connect the Pullup resistor on float switch (10K Ohm). It's good idea ?
30 Oct 2019 13:42 #149168
In that case it sounds like the problem is that the float switch is connected to the Z limit HAL input, and it shouldn't be. (Or, at least, you did not intend it to be?)
Time to create page: 0.149 seconds
