Forum Header
Need Help with Stepper Driver Timing settings
- SinfulDarkLord
02 Sep 2019 04:24 #143871
by SinfulDarkLord
Need Help with Stepper Driver Timing settings was created by SinfulDarkLord
Hi guys I need help in getting the driver settings for the interface board. I already checked the list of drivers here on Linuxcnc wiki, but the one I have is not listed. This is the one I have
www.omc-stepperonline.com/cnc-breakout-b...outer-kit-st-v2.html
Your help is most appreciated
- Mike_Eitel
- Thank you received: 185
02 Sep 2019 04:59 #143876
by Mike_Eitel
Replied by Mike_Eitel on topic Need Help with Stepper Driver Timing settings
The timing is needed for the motor-drivers parameter adaptation.
Not for a bob. Those can only be to slow if very fast pulses are send. F. X. When to high microstepping is chosen.
02 Sep 2019 06:15 #143882
by pl7i92
Replied by pl7i92 on topic Need Help with Stepper Driver Timing settings
hi
you may find ore infios
at my YT channel
as i use this boards for almost all my mashines
advice on timings and connection
at my YT channel
The following user(s) said Thank You: SinfulDarkLord
02 Sep 2019 12:19 #143894
by Leon82
Replied by Leon82 on topic Need Help with Stepper Driver Timing settings
What step drives are you using
02 Sep 2019 13:17 #143895
by pl7i92
very view ifos
you can also use a live Chat on the IRC channel server Freenode channel #linuxcnc to get infos right away
- SinfulDarkLord
02 Sep 2019 14:50 #143898
by SinfulDarkLord
Hi, I am using these.
www.omc-stepperonline.com/digital-steppe...er-motor-dm556t.html
Replied by SinfulDarkLord on topic Need Help with Stepper Driver Timing settings
02 Sep 2019 16:42 #143902
by pl7i92
hi the H versions from the 556 are little faster and the D version is the goal
but its ok
so you can set up 3500 3500 8000 5000
this will give you a very good start
my 6Axis got them shown here
but its ok
- SinfulDarkLord
02 Sep 2019 17:03 #143904
by SinfulDarkLord
Awesome, thank you very much. This is all new to me and I don’t want to mess up my 3K filament winder.
I have another question. On the settings for the pulses per revolution on the drivers, can I just select which ever and then input that in linuxcnc step config or do I need to find out the stepper motor’s max puls/rev?
but its ok
02 Sep 2019 18:50 #143920
by Leon82
Pulse per rev I'm assuming is the same as steps per rev so most likely 200 as it is most common.
You need to check the motor as some can be 400
Time to create page: 0.336 seconds
