Forum Header
TB6600 configuration issue servos won't move
22 Dec 2019 18:58 #153059
by jklmuk
TB6600 configuration issue servos won't move was created by jklmuk
Hello,
I have purchased a 3 axis TB6600 control board off ebay for a project i am working on but unfortunately i am struggling to get anything to move.
I have configured the pins as described in the following datasheet but whenever i run the axis test all that happens is relay 2 fires for a fraction of a second.
pappp.net/wp-content/uploads/2016/11/3_A...ard_Users_Manual.pdf
This suggests to me that the pulse signal is being sent to the relay channel. So i tried swapping the dir and step around and the relay fires and stays on. However, this happens when i test all tree axis.
I noticed in the datasheet pin 14 is listed as enable all so i searched the web and found the following solution:
forum.linuxcnc.org/27-driver-boards/2687...ble-axis-in-linuxcnc
which adds 3 lines to the custon.hal file but still doesn't work.
Can anyone tell me what i am doing wrong?
thanks
Jason
thanks
Jason
22 Dec 2019 19:02 #153060
by Clive S
Replied by Clive S on topic TB6600 configuration issue servos won't move
Welcome. It's always a good idea to post the hal and ini files from the config folder when looking for help.
22 Dec 2019 19:17 #153064
by jklmuk
Replied by jklmuk on topic TB6600 configuration issue servos won't move
Clive,
Thanks fro a quick response. Please find attached the files requested.
thanks
Jason
thanks
Jason
22 Dec 2019 19:19 #153065
by jklmuk
not sure why all the files didn't attach to previous post
22 Dec 2019 21:40 #153074
by AgentWD40
Replied by AgentWD40 on topic TB6600 configuration issue servos won't move
I thought the tb6600 was a stepper driver?
22 Dec 2019 21:42 #153075
by jklmuk
Replied by jklmuk on topic TB6600 configuration issue steppers won't move
Hi sorry I meant steppers.
Jason
Jason
22 Dec 2019 22:38 #153076
by Leon82
Replied by Leon82 on topic TB6600 configuration issue steppers won't move
Maybe try to tie machine.on to enable?
22 Dec 2019 22:45 - 22 Dec 2019 22:46 #153078
by Clive S
Not sure if I am on the correct track here but: In the hal file
setp stepgen.0.steplen 1 try 5000
setp stepgen.0.stepspace 0 try 5000
Clive,
thanks
Jason
Last edit: 22 Dec 2019 22:46 by Clive S.
- Thank you received: 5947
22 Dec 2019 23:19 #153079
Replied by tommylight on topic TB6600 configuration issue servos won't move
Please attach the correct hal and ini files.
Also what motors do you have, how are they wired to the board, what power supply, etc.
23 Dec 2019 05:19 #153082
by phillc54
Replied by phillc54 on topic TB6600 configuration issue servos won't move
Are you getting any error messages?I have purchased a 3 axis TB6600 control board off ebay for a project i am working on but unfortunately i am struggling to get anything to move.
He is using double step mode so 1 and 0 are correct, the "setp parport.0.reset-time 5000" line takes care of the timing.Not sure if I am on the correct track here but: In the hal file
Time to create page: 0.254 seconds
