Forum Header
Is my interpretation of the SD-2H044MA spec right?
12 Feb 2020 12:58 #157175
by jsven
Is my interpretation of the SD-2H044MA spec right? was created by jsven
Hi I'm setting up LinuxCNC for the first time and I have some problems regards to setting up the driver.
I don't know if I'm interpret ta data sheet correct, so if someone can confirm and maybe help me out a bit that we be most appreciated.
I have made these assumptions based upon the timing spec in the data sheet are those correct?
Step Time: 2500 ns
Step Space: 2500 ns
Direction Hold: 2000 ns
Direction Setup: 4000 ns
Datasheet can be found here: Data sheet
Step Time: 2500 ns
Step Space: 2500 ns
- Thank you received: 5944
12 Feb 2020 15:10 #157183
Replied by tommylight on topic Is my interpretation of the SD-2H044MA spec right?
You should really start with:
Step Time: 15000 ns
Step Space: 15000 ns
Direction Hold: 20000 ns
Direction Setup: 20000 ns
Only after you have the motor running properly, albeit slowly, then you can try:
Step Time: 5000 ns
Step Space: 5000 ns
As this should work with most drives, and if all is good but you can not get the speed you need, you can try lowering them a bit more.
Step Time: 15000 ns
Step Time: 5000 ns
Step Space: 5000 ns
The following user(s) said Thank You: jsven
12 Feb 2020 20:19 - 12 Feb 2020 20:21 #157215
by jsven
Replied by jsven on topic Is my interpretation of the SD-2H044MA spec right?
Thank you for your quick answer.
I will try the settings as you proposed.
Best regards
Johan
Best regards
Johan
Last edit: 12 Feb 2020 20:21 by jsven.
