Forum Header
Config file loaded?
15 Feb 2020 09:09 #157400
by htungh1
Config file loaded? was created by htungh1
I just installed linuxcnc, after configured with stepconf for my CNC(motor driver:tb 6560 v5), I test with each axis, which runs correctly. But, when I load into linuxcnc, it only runs half the distance from g-code, meaning for G0 X100, the real distance only 50mm, can anyone tell me what I got wrong? thanks in advance
- BeagleBrainz
- User is blocked
- Thank you received: 570
15 Feb 2020 09:21 #157401
by BeagleBrainz
Replied by BeagleBrainz on topic Config file loaded?
Gunna need to have a look at your hal & ini files and a mention of the hardware setup on the drive system. And your microstepping stepping on the drive and what you entrered.
But as a guess something is out by a factor of 2 or half.
- Online
- Thank you received: 5944
15 Feb 2020 10:00 #157405
Replied by tommylight on topic Config file loaded?
On the driver board there are some dip switches, you need to check that and input the microstepping value in the stepconfig.
Time to create page: 0.064 seconds
