Forum Header
Stepconf does not start
05 May 2020 18:05 #166783
by prochj51
Stepconf does not start was created by prochj51
I have problem running stepconf.
It gives following output
I did not change the script in any way.
I am using LinuxCNC master branch installed.
Would any of you know what problem might be?
So far I have been running PNCCONF, it runs fine.
Jiri
prochj51@linuxcnc:~$ stepconf
File "/usr/bin/stepconf", line 116, in <module>
from stepconf import build_INI
File "/usr/lib/python2.7/dist-packages/stepconf/build_INI.py", line 30, in <module>
importlib.reload(sys)
AttributeError: 'module' object has no attribute 'reload'
Jiri
06 May 2020 06:33 #166845
by bbsr_5a
Replied by bbsr_5a on topic Stepconf does not start
did you update from buildbot
or did you update after install at all
use the Packige manager to update your linuxcnc version
it does not effect any config at all
06 May 2020 07:01 #166850
by prochj51
Replied by prochj51 on topic Stepconf does not start
I updated it with Package manager.
I tried reinstallation of LinCNC master branch, still have the same issue.
07 May 2020 21:24 #166982
by nicokid
Replied by nicokid on topic Stepconf does not start
I just found out that stepconf can no longer work with Ubuntu 16.04
importlib.reload exists only in python3.
Also in ubuntu 16.04 there is no yapp package for python3.
The killer is rene-dev with the work of the last 5 days...
Nicola.
Nicola.
- Thank you received: 5944
07 May 2020 21:45 #166983
Replied by tommylight on topic Stepconf does not start
Who did he kill ?The killer is rene-dev with the work of the last 5 days...
07 May 2020 23:00 #166989
by nicokid
Stepconf is dead...
In my ubuntu 16.04 it no longer runs.
07 May 2020 23:50 #166995
by phillc54
Replied by phillc54 on topic Stepconf does not start
You should create a new issue if a similar one does not yet exist.
github.com/LinuxCNC/linuxcnc/issues
08 May 2020 07:37 - 08 May 2020 07:38 #167017
Replied by cmorley on topic Stepconf does not start
change line 38 in build_ini.py to :
reload(sys)
I should add if using python2
reload(sys)
Last edit: 08 May 2020 07:38 by cmorley.
08 May 2020 17:19 #167059
This is fixed properly in master now.
The following user(s) said Thank You: tommylight, nicokid
09 May 2020 20:52 #167175
by nicokid
Ok, many thanks.
Nicola.
Nicola.
