Forum Header
Newbie, configuring 6040z issues
- Matadormac
31 May 2020 17:57 #169539
by Matadormac
Newbie, configuring 6040z issues was created by Matadormac
Good day to the list.
I have a typical Chinese 6040z router with the typical JP-3163B controller. This is a 3-axis machine. Also, the typical SXCNC VFD control box.
I am using a fresh install of Lincuxcnc 2.7.4 on an older Pentium computer using its native parallel port. The computer appears to be working just fine. I believe my issues are solely with the LinuxCNC configuration.
1.8 degree stepper motors that came with the unit. Standard 1605 ball screw with 5mm pitch.
My current step config:
Step Time 10000 ns
Step Space 10000 ns
Direction Hold 10000
Direction Setup 10000
Micro Steps/Rev 320
Driver microstepping 16
Pulley teeth etc. 1:1
Leadscrew pitch 10 mm/rev
Max Velocity 10 mm/sec
Max acceleration 30 mm/sec/sec
When testing the X-Axis with the above settings and the 15mm range I get a consistent travel of 48 mm as measured with a ruler and not a caliper.
With Leadscrew set to 5 mm/rev I get a measured travel of 48 for the specified 15 mm test range.
I have searched various forums for info and think I am following the LInuxCNC documentation. So, I am stumped.
Any insights from the list would be appreciated. As a pretty much neophyte I am out of thoughts on what to do now.
Regards
Step Time 10000 ns
Step Space 10000 ns
Micro Steps/Rev 320
Regards
- Thank you received: 5944
31 May 2020 18:11 #169540
leadscrew pitch should be 5mm
The rest is OK.
48mm in both cases ???
Replied by tommylight on topic Newbie, configuring 6040z issues
Steps per revolution should be 2001.8 degree stepper motors that came with the unit. Standard 1605 ball screw with 5mm pitch.
Step Time 10000 ns
Step Space 10000 ns
Micro Steps/Rev 320
The rest is OK.
- Matadormac
31 May 2020 21:41 #169574
by Matadormac
Replied by Matadormac on topic Newbie, configuring 6040z issues
Thank you Tommylight.
I made the changes you suggested. Also, cleaned up some old config files, quit out and restarted the computer, linuxCNC and the router.
Tried the X axis with your settings and a 15 mm range of motion. 60 mm as measured by eye and ruler. Hmm, that being 4x the requested 15mm range of motion is that a clue?
If it is I wouldn't know what to do with it. Hope you can advise.
Best
Best
31 May 2020 22:03 #169579
Change that and make some chips.
That is a clue, you have microstepping on the drives set at 4, not at 16.Hmm, that being 4x the requested 15mm range of motion is that a clue?
- Matadormac
01 Jun 2020 15:15 #169675
by Matadormac
I believe I know why you suspect that microstepping was set to 4 but it wasn't. I went back and checked just now, redid the microstepping to 16 (just in case) and retried the 15 mm check. It is still travelling 60mm in total.
Is there some base setting I am missing or what do you advise I try next?
Thank you
Thank you
01 Jun 2020 15:22 #169678
You must be looking at the dip switches from the wrong side!
You have, and need to set the microstepping to 4 in the stepconf.
- Matadormac
01 Jun 2020 16:46 #169687
by Matadormac
OK, set microstepping to 4 in LinuxCNC. The router now moves 15mm when testing as it should BUT there is a horrendous almost grinding noise coming from the motor.
Regards
Regards
01 Jun 2020 18:33 #169696
That is normal fro steppers at low microstepping.
Now you can change the microstepping on the drives to 8 or 16, and do the same in stepconf.
- Matadormac
01 Jun 2020 21:42 #169723
by Matadormac
OK, but as a newbie I need to ask if I change from 4 microsteps to either 8 or 16 will that change the travel of the tool?
Thank you
Thank you
01 Jun 2020 22:04 #169727
Not if you change it on both the drives and stepconf.
Changing just one of those will result in erroneous travel of the machine.
Time to create page: 0.119 seconds
