Forum Header
Error with converting mach 3 file
- robertjenkins
14 Aug 2020 13:22 #178182
by robertjenkins
Error with converting mach 3 file was created by robertjenkins
Hello
I've just got a new (old) milling machine that came with the previous owner's mach 3 configuration files. I want to run it with linuxcnc and thought it would be easy to import the configuration files with the stepconf wizard.
However, I get the following errors, which unfortunately mean nothing to me. Would much appreciate help
Stepconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/lib/pymodules/python2.7/stepconf/pages.py", line 68, in on_button_fwd_clicked
if not self():
File "/usr/lib/pymodules/python2.7/stepconf/pages.py", line 188, in start_finish
from stepconf import import_mach
File "/usr/lib/pymodules/python2.7/stepconf/import_mach.py", line 52, in <module>
dom = parseString(data)
File "/usr/lib/python2.7/xml/dom/minidom.py", line 1930, in parseString
return expatbuilder.parseString(string)
File "/usr/lib/python2.7/xml/dom/expatbuilder.py", line 940, in parseString
return builder.parseString(string)
File "/usr/lib/python2.7/xml/dom/expatbuilder.py", line 223, in parseString
parser.Parse(string, True)
ExpatError: not well-formed (invalid token): line 1, column 401
if not self():
- robertjenkins
14 Aug 2020 13:29 #178183
by robertjenkins
Replied by robertjenkins on topic Error with converting mach 3 file
This is the xml file
Time to create page: 0.090 seconds
