Forum Header
Looking for someone to troubleshoot realtime in discord
- UntitledDocument
10 Sep 2020 15:55 #181649
by UntitledDocument
I created and ran my CNC machine for a few years and now decided to switch to linuxCNC which also required a new breakout board (PBX-RF) and that new breakout board requires a DB-25 connection. I bought a pci card (PCI I/O Parallel Port DB25 25Pin IEEE 1284 Printer Card Controller Adapter) wired up my CNC machine, triple checked my work, and made a computer exclusively for linuxCNC on 2.7.14 wheezy. I fired everything up it, heard the motors kick in as expected, and went through the stepconf as carefully as I could. I couldn't get a motor to spin on the test. I've read through a ridiculous amount similar problems, and tried all sorts of things. My only guess right now is that my pci card doesn't have a driver, but I can't even be sure on that. The parport in stepconf doesn't give it an address automatically, but it looks like it's available with the lspci -v looks like it is showing the card, I think. The pci card might not even be the problem.
If someone can have a call or video call over discord that would be super helpful. I don't enjoy the format of help where I have to keep trying random suggestions from anyone that types something into the forum. It's time consuming, and sometimes it hurts more than it helps.
I'm new to linux and linuxCNC, but I'm not a complete idiot. My diploma is for CAD/CAM Engineering Technology, and it involved a lot more than just CAD and CAM.
Thank you
Thank you
- Thank you received: 5944
10 Sep 2020 21:40 #181681
Replied by tommylight on topic Looking for someone to troubleshoot realtime in discord
Since this is an open source software/forum/everything else, we kind of hate money, but since you asked, are you willing to pay something for that time on call/video ?
Back on topic
The first thing to check is the PCI card, so what does "sudo lspci -v | grep par" say ?
There are plenty of those PCI cards that do not work with Linux as they are software type cards and need a special driver to translate things on the go, but most of them with MosChip or NetMos chips do work properly on Linux.
Back on topic
- UntitledDocument
11 Sep 2020 02:23 #181706
by UntitledDocument
Replied by UntitledDocument on topic Looking for someone to troubleshoot realtime in discord
"sudo lspci -v | grep par" asks for a password, I enter the password and then nothing happens.
I did try "cat /proc/ioports | grep par" and it says "0378-037a : parport0". 0378 is a common and ideal base address if I understand correctly, right?
I appreciate and value open source software, and I don't expect a customer service line, so I'll take what I can get. I just think that some problems are better solved with quick and focused communication, especially if everyone can see what they're talking about. That's why I asked. If that idea makes you tense, don't worry about it. I have no idea what I would pay for that help, but I think a good payment to the community would be to formally write out the problem and solution afterwards so that it's not drowned in 20 pages on a thread. These one-off problems can get overwhelming to read through on forums.
I'm not angry, I'm just explaining myself.
Your picture is really funny by the way. Thanks for your help so far
11 Sep 2020 06:48 #181725
Replied by Aciera on topic Looking for someone to troubleshoot realtime in discord
I really don't think your approach is doing you a favor, but we are helpful people so I hazard a "random" suggestion anyway.
Since you don't like to waste your time, why not invest in something that we actually know it works?
Like this:
store.mesanet.com/index.php?route=produc...=83_85&product_id=58
Like this:
- BeagleBrainz
- User is blocked
- Thank you received: 570
11 Sep 2020 07:43 #181730
by BeagleBrainz
Replied by BeagleBrainz on topic Looking for someone to troubleshoot realtime in discord
Well that's what you can do. Once you find your solution, do a write up.
You could also try "Par" vs "par" as the argument to grep or you could use the -i switch for grep with "par". It's not that "nothing happens" it's that grep hasn't found the string you told it to search for.
Historically 0x378 is the address of the parallel port. Ideal, hmm, I don't think there is an "ideal" base address. The address is the address.
Surely if you have the ability to get a diploma you have the ability to read through "20 pages", find a solution if there is one there and do a short concise write up. If you can't put the time in nor have the time maybe it would be better to pursue another activity that takes up less of your precious time.
11 Sep 2020 07:51 #181731
That is a nice and elegant reply, thank you.
We all do this in our spare time and this takes a lot of time, but it does help many people and stays here for a long time..
Back on topic
The 387 address points to the motherboard having a parallel port but the empty lspci result also points that the PCI card is not detected, so that seems like a software one.
Can you open the pc and check if there is a 26 pin header there, that would only require a simple cable with a DB25 connector.
When you start LinuxCNC do you get a warning on the lower right side saying parallel port not found ?
You can contact me here
www.tomberisha.com
But beware that i do not keep that whatsapp with me so i might not answer always, and i do not want any money, i will try ti help whenever possible given the time difference, and it would be nice if you post the results.
If you happen to come to Kosovo, you owe me a coffee!
Back on topic
www.tomberisha.com
- BeagleBrainz
- User is blocked
11 Sep 2020 08:03 #181734
by BeagleBrainz
Like I said the empty lscpi result is because grep is case sensitive, the -i switch causes grep to search for string disregarding case.
so either run
sudo lspci -v | grep -i par
or
sudo lspci -v | grep Par
so either run
or
- UntitledDocument
11 Sep 2020 16:52 #181772
by UntitledDocument
Thank you,
The motherboard does indeed have a 26 pin header in a rectangular pattern, with the 26th pin missing, and the writing beside says jprnt1, which I assumed and confirmed is meant for a printer cable. That idea makes a lot of sense to me. I'll have to use some jumper wires to match the db25 cable soon to test it.
- UntitledDocument
11 Sep 2020 16:57 #181774
by UntitledDocument
thanks for that last message BeagleBrainz,
the print out was:
04:01.0 parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
the print out was:
11 Sep 2020 17:55 #181778
by Clive S
How about one of these
www.ebay.co.uk/itm/LPT1-Parallel-Port-Pr...a:g:4KcAAOSwPzZfFa6T
You might have to get a gender changer for the DB25
www.ebay.co.uk/itm/2-pcs-25-Pin-Male-to-...4ca3b77b5d583e3103ef
Replied by Clive S on topic Looking for someone to troubleshoot realtime in discord
Thank you,
Time to create page: 0.106 seconds
