Forum Header
pico universal stepper stepconf wizard setup
21 Mar 2021 17:40 #203138
by dansawyer
pico universal stepper stepconf wizard setup was created by dansawyer
Linuxcnc install 2.8.0 Stepconf wizard setup question.
The system is linuxcnc 2.8.0. The stepper breakout control board is Pico Universal stepper.
The Stepconf parallel port 1 screen setup shows 12 output pins, 1 through 9 and 14,16,17
I assume this is configiuring P2 on the Pico Universal Stepper board. The Pico P2 shows 12 pins: power, gnd, +5, gnd, s0, d0, s1, d1, s2, d2, s3, and d3
My questions are:
1. Using Stepconf wizard wher are the correct pinouts to map to the Pioo Universal stepper?
2. The parallel port can control 12 output pins. P2 only identifies 8 output pins. Are the other 4 available on the Pioc board? If s where?
3. If so, how can they be mapped?
My objective is to create a Stepconf wizard setup to map to the Pico board.
Dan
My questions are:
Dan
21 Mar 2021 22:36 #203168
Replied by cmorley on topic pico universal stepper stepconf wizard setup
Unfortunately stepconf cannot configure for Pico.
You must set it up manually.
You could use stepconf to make a basic config, then modify the HAL files to suit Pico
22 Mar 2021 01:14 #203186
by dansawyer
Replied by dansawyer on topic pico universal stepper stepconf wizard setup
Thank you. That was disapointing but helpful.
Is there a documented mapping between the parallel port 1 config screen pins 1 through 9, 14, 15, and 17 and P2 of the and the USC board?
(Or is this question totally out of context and there is no relationship between the pin syntax in the Stepconf Wizard and the syntax necessary to define the USC board to linuxcnc? If this is the case is there a pointer to the documentation for this syntax? )
I am using Gecko drivers and have wired the USC to match the Gecko from a sheet labled Gecko - USC Connection. I can identify about 8 to 10 pin descriptors in the HAL that appear to map linuxcnc to those drivers. Is is as simple as replacing those lines with the appropriate pin descriptors or is there significantly more to it.
22 Mar 2021 22:54 #203315
Replied by andypugh on topic pico universal stepper stepconf wizard setup
There are several PPMC demo configs supplied with LinuxCNC.
Pick one from the config picker and it will be copied to your config folder for inspection.
(in many cases simply editing the INI entries to suit your machine will get you close)
Time to create page: 0.120 seconds
