Forum Header
old stepper motor with DM542A drivers and Raspberrypi 4
06 May 2021 20:03 #208152
by activa73
old stepper motor with DM542A drivers and Raspberrypi 4 was created by activa73
Hello,
I'm retrofit an old cnc lathe :
www.usinages.com/threads/retrofit-tour-j...micro-tour-2.142903/
but I can not find best parameters for Step motor controler DM542A(Step Time,...) and my stepper motor. (speed, acceleration...)
I can not used the "test Axis" in stepconf wizard because I use Raspbery PI and not parallel port.
In attached file you have my ini and my hal file.
Can you help me please.
BR
BR
- BeagleBrainz
- User is blocked
- Thank you received: 570
07 May 2021 08:45 #208190
by BeagleBrainz
Replied by BeagleBrainz on topic old stepper motor with DM542A drivers and Raspberrypi 4
This manual should give you some base figures:
sign-click.ru/upload/iblock/d03/d033c97c...854e60f3eb511b2e.pdf
This is the Linuxcnc manual for tuning:
linuxcnc.org/docs/2.8/html/motion/tweaking-steppers.html
Accel & Max Velocity are a machine by machine thing. Sound & feel help in this respect. I backed my machine down so I had some headroom. From what I remember it could go scary fast.
07 May 2021 09:29 #208194
by activa73
Replied by activa73 on topic old stepper motor with DM542A drivers and Raspberrypi 4
Thank you for the datasheet and the manual for linuxcnc.
I will try with these informations.
BR
BR
- BeagleBrainz
- User is blocked
07 May 2021 09:57 #208196
by BeagleBrainz
No probs, nice little lathe you have there.
Time to create page: 0.144 seconds
