Forum Header
Diferent motors on same axis
- Schneiderman
23 Aug 2021 14:00 - 23 Aug 2021 14:19 #218508
by Schneiderman
Diferent motors on same axis was created by Schneiderman
Hi guys!
I am new to LinuxCnc and in need for some help.
I know it is possible to connect two motors (same model/ same size and same gear ratio etc) on same axis.
I want to know if it is possible to connect two diferent motors, with diferent gear ratio and sizes, on the same axis. and how do I do that.
For example, I have a cnc type XZ and three diferent motors ( diferent gear ration and sizes).
Do I set the step conf to XYZ and attach Y axis to Zaxis??
Thank you in advance.
Last edit: 23 Aug 2021 14:19 by Schneiderman.
23 Aug 2021 14:08 #218513
Replied by andypugh on topic Diferent motors on same axis
Yes, it is possible. It isn't even difficult.
Just configure as normal, but set up the motors differently.
- Schneiderman
23 Aug 2021 14:16 #218517
by Schneiderman
Replied by Schneiderman on topic Diferent motors on same axis
Thank you Andy,
But please explain it to me further.
- Schneiderman
23 Aug 2021 14:18 #218519
by Schneiderman
bhank you Andy,
But please allow me to explain further.
26 Aug 2021 22:18 #218832
I think that Stepconf allows you to configure more than one motor per axis.
But I haven't used it for years. (I tend to largely configure by hand as most of what I do is unconventional)
It might help to understand that LinuxCNC reserves the word "axis" for the spatial coordinates, and uses "Joint" to refer to a motor / slide actuator.
So configure the joints according to the motor parameters and then allocate the joints to the axes.
Time to create page: 0.418 seconds
