Forum Header
Jogging
- OttoDidact
- Thank you received: 3
06 Sep 2021 08:47 - 06 Sep 2021 08:53 #219746
by OttoDidact
Replied by OttoDidact on topic Jogging
Glad you are back on track. Have fun.
For reference I cut at 80 to 150 inches per minute, depending on material. Approx 2000 to 3800mm/min.
Optimally cut speed is based on a formula related to spindle speed, bit diameter and material hardness. Or whatever approximation you have to do given the capabilities of your machine.
Last edit: 06 Sep 2021 08:53 by OttoDidact. Reason: Too brief
12 Sep 2021 10:36 #220284
I have fswizard on my phone, and find the numbers in there to be about correct.
Whereas I tend to cut at 50 to 80 mm/min. But that is because I have a 1000rpm spindle and I am generally cutting steel.For reference I cut at 80 to 150 inches per minute, depending on material. Approx 2000 to 3800mm/min.
Time to create page: 0.126 seconds
