- Configuring LinuxCNC
- StepConf Wizard
- Cannot return to zero after using stepconf to create two parallel ports
Forum Header
18 Mar 2022 04:19 #237610
by EdisonBin
Replied by EdisonBin on topic Cannot return to zero after using stepconf to create two parallel ports
Thank you very much. Now my problem has been solved. It's the wrong port number. Thank you, brother
24 Jun 2023 08:56 #274165
by masawee
Replied by masawee on topic Cannot return to zero after using stepconf to create two parallel ports
but mesa have problem use, normal hobby user not have budget buy mesa cards because have lot lot lot owerprice and expensive cards. normal user not newer waste money mesa card, thats is why most user use only cheap chinese BOB boards, just i orden second BOB board and adding second paraller port too , can use more input, 1st board have all limit,E-stop , probe and 2th board have all homing ,and can add some relay later to second board, water,fan,spindle,RPM arduino oled gauge on/off, etc. need only orden later some SSR 25A relay can controller spindle and other stuff.
- StepConf Wizard
