Forum Header
New (to me) computer. Now only one Z stepper works.
23 Mar 2022 07:58 #238081
by muzza
Replied by muzza on topic New (to me) computer. Now only one Z stepper works.
Both computers are running 2.7.15
23 Mar 2022 08:06 #238082
Replied by rodw on topic New (to me) computer. Now only one Z stepper works.
Really if you are setting up a gantry machine with 2 motors on the Y axis, V2.7 is not the way to go
2.8 gives much better support for this via Joint axes.
But the question remains If you had a working config, why didn't you just copy it to your new PC?
23 Mar 2022 08:17 - 23 Mar 2022 08:20 #238083
by muzza
A. Because I didn't know could do that.
B. Because I don't know how.
C. Because I wouldn't know which files to copy or where to find them.
Linux is a whole new kettle of fish for me. A VERY steep learning curve for a 62 year old...
Is upgrading to 2.8 very complicated? I've only gotten this far by successfully utilising my 'monkey see, monkey do' skills.
Last edit: 23 Mar 2022 08:20 by muzza.
23 Mar 2022 08:52 #238086
by Clive S
Re B. Because I don't know how.
use a usb stick and copy the contents of the config folder from the old pc to the new one.
Replied by Clive S on topic New (to me) computer. Now only one Z stepper works.
23 Mar 2022 13:13 #238098
by muzza
B. leads in to C.
I know how to copy files from one computer to another. But where are the files?
You both make the assumption that I know this stuff. I don’t. That’s why I’m asking for your help.
- Thank you received: 5951
23 Mar 2022 13:23 #238099
Replied by tommylight on topic New (to me) computer. Now only one Z stepper works.
On most Linux distros, there is a Home folder on the desktop, click on that, inside it there will be another folder with your user name, click on it, now you have several folder but one of them is always named "linuxcnc", open it, there are two folders one is named "config", inside it is the folder with your machine name, right click on it and choose copy, then select the USB device on the left side of the file explorer and right click on it, choose paste.
The following user(s) said Thank You: muzza
23 Mar 2022 13:43 #238101
by Clive S
Yes B leads to C. You have already found where the files are by showing the ini and hal files.
If not where did you find them ?
B. leads in to C.
24 Mar 2022 00:19 #238178
by muzza
My response was to "why didn't you just copy the working config to the new computer". The .hal and .ini files aren't the config.
or are they?
Maybe I should have written "which files" instead of "where are they"
This stuff may be bread and butter to you experts, but geez you make a lot of assumptions about the ability and knowledge of the person asking the question. Don't get me wrong, I appreciate the help, but I can't help but notice a touch of aloofness.
I tried copying what I THOUGHT might be the config to the new computer, but then I couldn't make a connection at all. The start button on the top left is greyed out and not doing anything.
Thank you Tommylight for the concise instruction. I'll try that tonight when I get home from work.
or are they?
24 Mar 2022 21:22 #238274
Are you jogging "Y" and expecting both "Y" motors to move? Ir are you jogging Y2 as an "A" axis at the moment?
Replied by andypugh on topic New (to me) computer. Now only one Z stepper works.
They are most of it. The "config" is that whole folder where the HAL and INI are located.My response was to "why didn't you just copy the working config to the new computer". The .hal and .ini files aren't the config.
or are they?
25 Mar 2022 06:27 #238303
by muzza
Thanks Andy. I was trying to jog both Y motors at the same time.
I followed the instructions given by Tommylight above and it now works properly.
I still don’t understand why the other config didn’t work as I followed the exact same setup procedure.
One day, when I’m REEEEEALLY bored, I might look at the new and old .ini and .hal files side by side and see if I can find the difference.
Time to create page: 0.308 seconds
