Forum Header
step adjustment
09 Apr 2022 14:35 #239737
by vk7dy
step adjustment was created by vk7dy
hi , how do i adjust me steps. eg..when i do 20 x20 box it measures 18.5 and the z is out as well, target depth for 10mm is only going 8.mm and stops
thanks Ken from Tasmania
09 Apr 2022 14:55 #239741
Replied by PCW on topic step adjustment
If you want to set the scales empirically, you could set
the joint 0 and joint 1 step scales to their current value *18.5/20
and the joint 3 step scale to its current value * 8/10.
Time to create page: 0.133 seconds
