Forum Header
Enabling StarTech PEXIP2 Parallel Port Card (AX99100)
23 Jun 2022 02:23 #245645
by longtimer
Enabling StarTech PEXIP2 Parallel Port Card (AX99100) was created by longtimer
Sorry if this is the wrong location. I was not sure on the appropriate one.
I have been trying to get a parallel port card that works with LinuxCNC and finally purchased the StarTech PEXIP2 PCIE card thinking that it would work based on the following posts:
forum.linuxcnc.org/42-deutsch/43693-para...-treiber-instalieren
forum.linuxcnc.org/24-hal-components/459...d-but-stepconf-works
Unfortunately, I am not sure what I am missing and the card is not working.
I am using the latest version of LinuxCNC
Linux cnc 4.19.0-17-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.194-3 (2021-07-18) x86_64 GNU/Linux
When I run 'lspci -k', I get the following indicating that no drivers or kernel modules were loaded for it so I think that this is the core issue:
02:00.2 Parallel controller: Asix Electronics Corporation Device 9100
Subsystem: Device a000:2000
Likewise, listing /dev shows no parportX entries.
When I run 'lspci -v', I get:
02:00.2 Parallel controller: Asix Electronics Corporation Device 9100 (prog-if 03 [IEEE1284])
Flags: bus master, fast devsel, latency 0, IRQ 7, NUMA node 0
I/O ports at d880
I/O ports at d800
Memory at feafd000 (32-bit, non-prefetchable) [size=4K]
Memory at feafc000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
As per the first link to the linuxcnc forums above, there is a zip file with make files and code for the driver. However, it is dependent on the contents of /lib/modules/4.19.0-17-rt-amd64/build/ and I am not sure which source to download or if it was required based on the forum posts mentioned above. It didn't seem like a build was ultimately required.
Any suggestions on how to proceed would be appreciated.
Thanks,
Jason
I/O ports at d880
I/O ports at d800
Thanks,
Jason
- Thank you received: 5949
23 Jun 2022 11:05 #245665
Replied by tommylight on topic Enabling StarTech PEXIP2 Parallel Port Card (AX99100)
Use "sudo" in front of lspci to see the drivers in use.
23 Jun 2022 14:52 #245683
by longtimer
Replied by longtimer on topic Enabling StarTech PEXIP2 Parallel Port Card (AX99100)
Thanks for the reply. I see that I did not run the second command as root user. However the first command was run as root and the list of kernel drivers/modules is empty - 'lspci -v' gives only the following:
I/O ports at d880
I/O ports at d800
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
In contrast, I can see kernel modules and drivers for the USB, video, audio, etc.
I/O ports at d880
I/O ports at d800
23 Jun 2022 15:19 #245689
In hal
loadrt parport "0xd880 out"
Should do the trick, if it does not change to 0xd800 and reboot the pc.
Although not listing the driver is strange, it still might work, but you never know without testing, so test with something attached to it.
23 Jun 2022 16:00 #245695
by longtimer
I tried changing from
loadrt hal_parport cfg="0 out"
to
both options
loadrt parport cfg="0xd800 out"
and then
loadrt parport cfg="0xd880 out"
but it gave me the following: parport: dlopen: /usr/lib/linuxcnc/modules/parport.so: cannot open shared object file: No such file or directory
so I reverted back to options
loadrt hal_parport cfg="0xd800 out"
and then
but no success.
Is it likely that I have to build a driver? If so, where would I pull the kernel headers from for this distribution?
to
both options
and then
and then
but no success.
23 Jun 2022 16:19 #245698
sudo modprobe parport
23 Jun 2022 16:31 #245699
by longtimer
modprobe parport returns nothing
23 Jun 2022 17:32 - 23 Jun 2022 17:34 #245705
That is OK, if it did something would be off.
Did you do another lspci or cat after running modprobe?
Edit:
or did you try running LinuxCNC after?
Edit:
Last edit: 23 Jun 2022 17:34 by tommylight. Reason: more info
23 Jun 2022 18:03 #245709
by longtimer
I did try running with 0xd800 and 0xd880 addresses individually in the hal without success following the 'modprobe parport' commend. In both cases, the same complaint came that there was no parallel port at that address. I know that the parallel port has some output because whenever I reboot the computer, I can hear the servos click momentarily. That doesn't happen if the parallel port cable is not connected.
23 Jun 2022 18:12 #245711
If it is happening after say a second or two of pressing the power button, that would be more promising.
I would not bet on it, it can be due to outputs getting tied to ground on boot.I know that the parallel port has some output because whenever I reboot the computer, I can hear the servos click momentarily. That doesn't happen if the parallel port cable is not connected.
Time to create page: 0.624 seconds
