Forum Header
Driver Stepconf info Power Step
10 Apr 2023 22:26 #268788
by JohnAlex3
Driver Stepconf info Power Step was created by JohnAlex3
Hello, I am new here and I feel silly asking about this. I am trying to establish Step Time, Step Space, Direction Hold, and Direction setup from the attached
10 Apr 2023 22:45 #268791
Replied by PCW on topic Driver Stepconf info Power Step
The timing minimums are
DIr Setup 5000 ns
Dir Hold 5000 ns
Step Pulse 2000 ns
Step Space 2000 ns
I would multiply these numbers by 1.5 to guarantee some margin
in the actual Stepconf setup
DIr Setup 5000 ns
Dir Hold 5000 ns
Step Pulse 2000 ns
Step Space 2000 ns
10 Apr 2023 22:57 - 10 Apr 2023 23:03 #268794
by JohnAlex3
Replied by JohnAlex3 on topic Driver Stepconf info Power Step
Thank you. That confirms I understand it at least a little. I really was questioning the Direction Hold.
Can I ask why the 1.5 multiplier for margin?
And can you tell me just for that first page of the Stepconf wizard, what in the ini and Hal files are affected? I have a setup already running with way more conservative values, and I don’t want to use the wizard because of it overwriting. What was going to do is make a test configuration and copy the changes.
Last edit: 10 Apr 2023 23:03 by JohnAlex3.
10 Apr 2023 23:06 #268797
Typically those settings are in the .ini file
The 1.5 margin is because those are _minimum_ settings
- Thank you received: 5944
13 Sep 2023 12:04 #280622
Replied by tommylight on topic Driver Stepconf info Power Step
Spammer booted.
Time to create page: 0.070 seconds
