Forum Header
How to open stepconf for linuxcnc installed by source code
17 Jul 2023 06:59 #275627
by szl
How to open stepconf for linuxcnc installed by source code was created by szl
I installed linuxcnc2.9 from source on my debian10 system, no boot icon found, only boot from terminal, how should I configure my CNC
17 Jul 2023 08:58 #275633
Replied by rodw on topic How to open stepconf for linuxcnc installed by source code
Sounds like you have built a Run in place system. stepconf should run from the command line once the rip-environment is set.
To get the menu, you need to build and install the .Deb packages.
It's all documented here:
linuxcnc.org/docs/2.9/html/code/building-linuxcnc.html
I did do a video
I did do a video
Time to create page: 0.076 seconds
