Forum Header
Importing imperial toolset into CNC
27 Feb 2024 21:40 #294647
by Basemetal
Importing imperial toolset into CNC was created by Basemetal
Hi all,
Extreme newbie here, with what I hope isnt too vague a question, im going round and round on google and getting nowhere fast.
We have upgraded recently to CNC running linux for our plasma cutter.
We want imperial measurements as we are NZ based, we have imported the toolset into Sheetcam, but are having trouble getting the same toolset into CNC.
Does anyone have any knowledge on this or can point me in the right direction?
Im also emailing the rep in USA but with the time difference its a bit of a battle.
Thanks in advance, Amber, admin of an Engineering business :O
02 Mar 2024 11:26 #294903
Replied by andypugh on topic Importing imperial toolset into CNC
I am a bit puzzled who you are contacting in the US, as I think that SheetCAM is based in the UK...
This is probably the wrong part of the forum. Are you running Plasmac?
02 Mar 2024 21:03 #294946
Replied by rodw on topic Importing imperial toolset into CNC
You would need to set the machine to be imperial in your ini file.
I am assuming you use metric units in your shop. So,
In sheetcam, select metric and edit your tool sets to be in metric units. Clean it up so it only has the tools you want.
Save/export your tool settings, then import into Qtplasmac. I think this is still via a seperate program, so check the docs on how to do this.
You may also need to change the settings at the top of the postprocessor, to use the QTplasmac defaults, not sheetcam''s
Time to create page: 0.101 seconds
