EMC2 running on Raspberry Pi?
15 Jan 2013 23:23 #28727
by wyzarddoc
Replied by wyzarddoc on topic EMC2 running on Raspberry Pi?
Thanks so much for the link. I'll check it out.
20 Jan 2013 09:50 #28849
by kinsa
Replied by kinsa on topic EMC2 running on Raspberry Pi?
Did anyone got to compile linuxcnc for the ARM platform besides the simulator mode?
Regards
Regards
21 Jan 2013 17:48 #28909
by ArcEye
Replied by ArcEye on topic EMC2 running on Raspberry Pi?
All the discussion etc is on the developers list
sourceforge.net/mailarchive/forum.php?forum_name=emc-developers
I think they dropped the RPi as being too low powered to make a realistic platform, but there was quite a lot of work on the Beagelbone.
21 Jan 2013 18:04 - 22 Jan 2013 11:30 #28912
by kinsa
I haven't found the instructions to compile under Beaglebone either. Only the simulator mode.
UPDATE:
Got it!
UPDATE:
Got it!
./configure --with-platform=beaglebone/raspberry
Last edit: 22 Jan 2013 11:30 by kinsa. Reason: Solved
24 Jan 2013 15:32 #29066
by kinsa
I've got it running under Xenomai. Initial results seems good but not suitable for sw stepgen. I'm planning to pair this with a low cost FPGA board and see how it goes.
24 Jan 2013 17:23 #29068
by mhaberler
Replied by mhaberler on topic EMC2 running on Raspberry Pi?
To build for Xenomai, 2 conditions must hold:
- the Rpi must be running a Xenomai kernel
- the Xenomai userland support package must be installed (git.xenomai.org/?p=xenomai-2.6.git;a=summary)
configure.log will tell how that detection goes.
As far as I am concerned, the raspberry platform option will stay in the code, but I will not put any effort into packaging or usability; if somebody else does, I'm happy to integrate patches.
- Michael
- Michael
13 Feb 2013 14:43 - 13 Feb 2013 18:51 #30003
by kinsa
Just an update, I was able to offload the base thread to an external PIC micro using SPI.
My observation is that bit-banging an 8 bit data bus is not optimal. The RPi SPI has 64 bytes of buffer so transferring data is quick with minimal cpu overhead.
I'm currently running the SPI clock at 15 MHz, a 64 bytes transfer completes in around 45 us. The maximum SPI speed that the RPi can operate at is 31 MHz. This is too fast for a PIC but doable with an FPGA.
Cheers!
UDPATE:
I finished porting my rt-8p8c code to the new PIC micro.
It's currently running using the mini tk interface over ssh.
Here is the output of top with backplot enabled:
Cheers!
UDPATE:
top - 10:48:06 up 9:58, 2 users, load average: 0.53, 0.60, 0.56
Tasks: 59 total, 1 running, 58 sleeping, 0 stopped, 0 zombie
%Cpu(s): 38.7 us, 6.6 sy, 0.0 ni, 53.1 id, 0.0 wa, 0.0 hi, 1.6 si, 0.0 st
KiB Mem: 498864 total, 204120 used, 294744 free, 21304 buffers
KiB Swap: 0 total, 0 used, 0 free, 117996 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6547 root 20 0 29216 12m 4936 S 35.2 2.6 8:51.26 wish8.5
6546 root 20 0 11548 5224 4520 S 5.2 1.0 2:00.87 milltask
4237 root 20 0 10496 3368 2360 S 3.9 0.7 1:29.53 sshd
6537 root 20 0 30040 11m 6144 S 2.9 2.4 0:47.77 hal_manualtoolc
6553 root 20 0 4620 1340 1024 R 1.3 0.3 0:10.15 top
2972 root 20 0 9504 3092 2364 S 0.3 0.6 0:29.58 sshd
6524 root 20 0 4128 1728 1440 S 0.3 0.3 0:03.32 io
1 root 20 0 2104 712 612 S 0.0 0.1 0:02.03 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.02 ksoftirqd/0
5 root 20 0 0 0 0 S 0.0 0.0 0:04.17 kworker/u:0
6 root -2 0 0 0 0 S 0.0 0.0 0:02.12 rcu_kthread
7 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
9 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
10 root 20 0 0 0 0 S 0.0 0.0 0:00.23 sync_supers
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 bdi-default
Last edit: 13 Feb 2013 18:51 by kinsa. Reason: updates
15 Feb 2013 11:32 #30090
by kinsa
I have created a wiki page: wiki.linuxcnc.org/cgi-bin/wiki.pl?RaspbianXenomaiBuild documenting the steps I took to create a working Xenomai LinuxCNC image for RPi.
15 Feb 2013 16:00 #30096
by JZHA1985
Replied by JZHA1985 on topic EMC2 running on Raspberry Pi?
A kickstarter if/when things come together would be nice, although I know that's far from a simple ordeal.
15 Feb 2013 16:28 #30098
by mhaberler
It is possible to run LinuxCNC on the Rasberry - in principle. It compiles, and runs on a Xenomai kernel.
that said, be advised that at least with Axis, the Pi runs out of CPU cycles badly - you might want to adjust your expectations downwards a bit.
- Michael
- Michael
