New computer won't run Ubuntu GUI
28 Feb 2010 09:44 #2110
by mickelsen
New computer won't run Ubuntu GUI was created by mickelsen
I have a new computer that doesn't seem to want to run the Ubuntu GUI. It is built with an MSI motherboard with built-in graphics, the ATI Radeon HD 3300 graphics hardware. GPU-Z, running under windows, says that the driver is atiumdag 8.14.10.0678/Win7. I didn't think that this had anything to do with nVidia drivers or hardware, but maybe I'm wrong. Can anyone give me an idea as to why this wouldn't run Ubuntu 8.04?
Thanks,
Mark
Thanks,
Mark
28 Feb 2010 19:01 #2126
by BigJohnT
Replied by BigJohnT on topic Re:New computer won't run Ubuntu GUI
I just installed a new mobo in my Hardinge lathe and it would not work with 8.04 from the LiveCD. I downloaded Ubuntu 8.04.4 and loaded that. Then installed EMC and the real time kernel. Then I deleted the std kernel so it would boot to the proper one.
some info here
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Installing_EMC2
some info here
28 Feb 2010 19:18 #2127
by mickelsen
Replied by mickelsen on topic Re:New computer won't run Ubuntu GUI
Thanks for the help, but I was hoping to be able to try this without permanently installing it yet. Would anyone know why the LiveCD version wouldn't work when the permanent installation does?
Thanks again,
Mark
Thanks again,
Mark
01 Mar 2010 06:51 #2131
by mickelsen
Since I can't get this to boot from the LiveCD disk, can someone tell me where I can find instructions on how to set my computer up for dual booting between Windows 7 and Ubuntu 8.04 with Emc2?
Thanks,
Mark
Thanks,
Mark
01 Mar 2010 12:58 #2135
by BigJohnT
You can download and burn the Ubuntu 8.04.4 LiveCD and test that Ubuntu will work.
01 Mar 2010 13:27 #2136
by mickelsen
John,
I've done that and the CD that I burned runs on other computers just fine. But it doesn't run on my new computer and I can't figure out why not. It should. Do you know of a place where I can get an image of Ubuntu 8.04 without Emc2 that I can download and burn onto a CD to try? That might tell me something.
Thanks,
Mark
Thanks,
Mark
01 Mar 2010 13:43 - 01 Mar 2010 13:44 #2137
by BigJohnT
Mark,
You don't understand, you need 8.04.4 not 8.04.0. The EMC LiveCD uses 8.04.0. Go to ubuntu.com to download the LiveCD with the latest version of Ubuntu which is 8.04.4
Then try booting from that CD.
JT
JT
Last edit: 01 Mar 2010 13:44 by BigJohnT.
01 Mar 2010 14:49 #2140
by mickelsen
Okay, I'm downloading that even as I type. Is it then possible to create a LiveCD that has Ubuntu 8.04.4 and Emc2 on it? Can I boot with 8.04.4, install Emc2, and then somehow save that configuration away and burn it on a boot-able CD that will run without modifying my computer (don't want much, do I)?
01 Mar 2010 17:06 #2143
by mickelsen
Okay. My new computer boots just fine with ver. 8.04.4. Is there a way to get a LiveCD with 8.04.4 AND Emc2 on it?
- chrisadam2
06 Sep 2010 10:00 - 06 Sep 2010 12:02 #3997
by chrisadam2
Replied by chrisadam2 on topic Re:New computer won't run Ubuntu GUI
If you can't start the Live USB system from a running Ubuntu Live CD ... USB key stick installs are screwed -- the desktop won't appear when you login. ..... Do not forget to check if the computer you are going to use the drive on ... UNetbootin automates this task by providing a GUI to create.
Last edit: 06 Sep 2010 12:02 by BigJohnT. Reason: remove ad
Time to create page: 0.270 seconds
