parallel port test help
05 Mar 2019 23:04 #127838
by spicer
Replied by spicer on topic parallel port test help
Ok. I ordered the 5 Axis MACH3 CNC Breakout Board from Ebay now.
This (blue) board work not
06 Mar 2019 02:43 - 06 Mar 2019 02:44 #127856
by Leon82
Replied by Leon82 on topic parallel port test help
Most of the boards I've seen on ebay have the optical isolation so you have to supply a separate power supply to the inputs.
The sainsmart Bob is not isolated and only needs the usb or 5 volt power
Last edit: 06 Mar 2019 02:44 by Leon82.
The following user(s) said Thank You: spicer
06 Mar 2019 07:48 #127867
by pl7i92
Replied by pl7i92 on topic parallel port test help
the Green ones also give you the option of using the
Cable set JST-XH-3S
also they supply the 0-10V for the VFD control
Cable set JST-XH-3S
Time to create page: 0.099 seconds
