Linuxcnc terminated with an error !!
20 Feb 2016 17:37 - 21 Feb 2016 15:25 #70407
by gizmo6023
Linuxcnc terminated with an error !! was created by gizmo6023
disregard
Last edit: 21 Feb 2016 15:25 by gizmo6023.
20 Feb 2016 18:26 #70408
by BigJohnT
Replied by BigJohnT on topic Linuxcnc terminated with an error !!
Clear dmesg with sudo dmesg -c run linuxcnc save the output from dmesg to a text file like this dmesg > errors.txt then attach the text file to your message.
JT
JT
20 Feb 2016 18:53 - 21 Feb 2016 15:24 #70409
by gizmo6023
Replied by gizmo6023 on topic Linuxcnc terminated with an error !!
Last edit: 21 Feb 2016 15:24 by gizmo6023.
21 Feb 2016 00:43 #70419
by BigJohnT
If you had followed my instructions you would have a text file...
JT
JT
The following user(s) said Thank You: gizmo6023
Time to create page: 0.144 seconds
