- Hardware & Machines
- Computers and Hardware
- Latency about 7000 with Latency-Test, raises to above 100.000 with latency-plot
- DomCa
- Thank you received: 6
17 Jan 2017 14:03 #85918
by DomCa
Latency about 7000 with Latency-Test, raises to above 100.000 with latency-plot was created by DomCa
Hi all!
I used the LinuxCNC download and installed from a USB stick. I just set up a PC (old dual core Athlon). I got it down to latencies about 7000 or lower for both threads. I deactivated everything in the bios and shifted the IRQs to the core 0.
I run 4 glxgears, buck bunny in 1080 30fps and browse on the internet.
The latencies stay low if I use the latency test. But they immediatly go up if I use the latency-plot.
Any idea?
DomCa
Any idea?
DomCa
- Thank you received: 5308
17 Jan 2017 14:32 #85923
Replied by PCW on topic Latency about 7000 with Latency-Test, raises to above 100.000 with latency-plot
No idea why you get such different results, but you might try latency-histogram as an additional data point
- DomCa
18 Jan 2017 06:26 #86034
by DomCa
Replied by DomCa on topic Latency about 7000 with Latency-Test, raises to above 100.000 with latency-plot
Hi PCW,
Thanks for the tip. I tried it and get the same result. I can run for 2-3 hours with the latency-test showing under 7000 and when I start the latency-plot or - histogram after some seconds there are some realy high values 20.000 up to 100.000 or even more. Not permanently but spikes...
Which values can I trust? I hoped the PC would be good for LinuxCNC.
Regards
DomCa
Regards
DomCa
- Bari
- Thank you received: 234
02 Mar 2017 18:55 #88895
by Bari
Replied by Bari on topic Latency about 7000 with Latency-Test, raises to above 100.000 with latency-plot
I just compared -test to -plot and -histogram and I got the highest latency test results using -test. This was tested on only one board/cpu using the latest kernel in LCNC 2.7.8 for only about 12 hours for each test.
Time to create page: 0.215 seconds
