Touchscreen and LinuxCNC
- timmert
16 Feb 2017 17:31 #88062
by timmert
Touchscreen and LinuxCNC was created by timmert
Hi
I want to use a 10" touchscreen for my LinuxCNC computer. Does every touchscreen work with Linux? Or are there special things to check before buying a screen. I have no experience with touchscreens on Linux.
Cheers
Cheers
- Thank you received: 1476
16 Feb 2017 18:47 #88064
Replied by Todd Zuercher on topic Touchscreen and LinuxCNC
No, but most do. Check with the manufacturer to see if they have Linux support. If it doesn't work out of the box, usually some drivers may need installed and or calibrated.
- timmert
16 Feb 2017 19:25 - 16 Feb 2017 19:32 #88068
by timmert
Replied by timmert on topic Touchscreen and LinuxCNC
I'm thinking about a raspberry pi screen, so should work
www.ebay.com/itm/Raspberry-Pi-10-touch-s...1:g:xSQAAOSwZJlXNBqW
but too low resolution for gmoccapy
Last edit: 16 Feb 2017 19:32 by timmert.
- Jake
- Thank you received: 10
17 Feb 2017 22:33 #88135
by Jake
Replied by Jake on topic Touchscreen and LinuxCNC
I have an ELO touchscreen on the way. Looks like it was a take out of a kiosk or something. eBay, less than $100. From what I found the ELO is supposed to work just fine with Linux.
- BigJohnT
- Thank you received: 994
17 Feb 2017 23:25 #88140
by BigJohnT
Replied by BigJohnT on topic Touchscreen and LinuxCNC
I have two ELO's that work with Ubuntu 10.04, just take a little fiddling with the configuration file to calibrate it. Might be easier on newer OS's
JT
JT
- timmert
18 Feb 2017 08:31 #88164
by timmert
ok thanks for the information
Time to create page: 0.244 seconds
