Volenteers to help me put together my 3axis mill
- MAG45
03 Mar 2017 03:29 #88912
by MAG45
Volenteers to help me put together my 3axis mill was created by MAG45
I have a ShopTask Eldorado that was set up by a friend with LinuxCNC years ago. I has since gotten unreliable and its a wiring nightmare. Rather then track down the problem I want to take it all apart and start over. I got a new BOB as the one in there is suspect to have issues.I originally planned to just swap the BOB but the pinouts of the two dont seem to be just a wire by wire swap. And trying to figure it out is when i saw all the other issues.
I am looking for someone who can help walk me through redoing this machine so i can learn and understand what everything does.
- MacGalempsy
03 Mar 2017 07:15 #88916
by MacGalempsy
Replied by MacGalempsy on topic Volenteers to help me put together my 3axis mill
Welcome to the club. Reading the manuals is the best way to get started. You may also start a build log where others with the same machine can add lib when needed.
Good luck!
Good luck!
- MAG45
03 Mar 2017 14:40 #88927
by MAG45
Replied by MAG45 on topic Volenteers to help me put together my 3axis mill
I have had little luck finding any manuals on basic wiring an building the system. Do you have any links?
- Thank you received: 7461
03 Mar 2017 14:58 #88932
Replied by tommylight on topic Volenteers to help me put together my 3axis mill
First get all the make and models of the electeonics, motors, ball screws or pulleys or gear ratio, computer and version of linuxcnc installed etc etc.
We need more info.
Manufacturer data change all the time, and they do not share to much info about the machines.
We need more info.
- MacGalempsy
05 Mar 2017 06:50 #89025
by MacGalempsy
Agreed. My first project led to lots of photos of various existing connections with systematic labeling. Also, listing each component and downloading manufacturer spec sheets helped with pinouts on motors, drivers, encoders, etc... For older parts, many were found using TheWayBackMachine. In all, being the first time (literally zero experience) taking on such an endevor, it was a few months to get a good handle on things.
Time to create page: 0.437 seconds
