Strech and touchscreen
- Mike_Eitel
- Thank you received: 183
04 Sep 2017 14:48 #98482
by Mike_Eitel
Replied by Mike_Eitel on topic Strech and touchscreen
Thx Andy.
That utility does not work. It does not find a device, also my screen works fine, just heavily misscalibrated.
In strech they changed devicenames. It's no more eth0, so maybe the touchscreen driver does simmilar...
I wonder if i realy need strech?
Mike
Mike
- Mike_Eitel
11 Oct 2017 17:44 #100220
by Mike_Eitel
Hi
Took a while but now I have a calibrated touchscreen.
I deinstalled libinput and installed evdev system. And xinput-calibrator calibrator.
All as root.
I loaded 99-cal..... In usr/share/X11 as proposed.
Never saw the values in that file as start values in xinput-calibrator...
Switched to normal user...
I also, not completely understood why needed but, had to set permission of the usr/share/X11 directors to rw for all three.
Now I saw a reaction and also xinput-calibrator showed the values in the file. Can not use the resulting values of that program, but with some systematic try and error I found the needed values.
All as root.
- verkbr
- Visitor
08 Jan 2018 14:13 - 08 Jan 2018 14:15 #104162
by verkbr
Replied by verkbr on topic Strech and touchscreen
getting a touchscreen (egalax) to work is easy to do:
get the driver from the Eeti website. Unpack driver. Go to folder and do sudo sh setup.sh.
Then it still does not work. Go to usr/share/X11/xorg.conf.d
then change with nano the file 53-egalax-virtual.conf. Replace void with evdev.
install:
apt-get install xserver-xorg-input-evdev
And then the Touchscreen works.
You only need the calibration. Install xinput-calibrator. touch the 4 crosses on the screen and copy the outcome.
Put the outcome in 10-evdev.conf same folder as before.
Bram
install:
Bram
Last edit: 08 Jan 2018 14:15 by verkbr.
- tecno
- Thank you received: 127
04 Jun 2018 17:20 #111610
by tecno
Replied by tecno on topic Strech and touchscreen
Above is not for non-HID type, tried to install but no-go.
Time to create page: 0.196 seconds
