- Hardware & Machines
- Computers and OS's
- End 2017 PC Build for 7I77 retrofit : which motherboard, cpu, video card ?
15 Oct 2017 10:11 #100380
by JC10
Hi there,
I have been lurking for months but now it is time to take action.
I will order soon a kit with a 7i77 for the retrofit of a VMC.
I have read many posts on various forums about what motherboard to use. But most of the time, the posts are old and the motherboard is not available anymore for sell.
In addition, I am hesitating on 5i25 or 6i25 because of the motherboard. The motherboards with PCI bus are becoming rare.
I intend to use a touch screen later so I would like to have a good hardware to cope with.
Thanks for help.
Thanks for help.
19 Oct 2017 15:14 #100557
Replied by andypugh on topic End 2017 PC Build for 7I77 retrofit : which motherboard, cpu, video card ?
www.newegg.com/Product/Product.aspx?Item=N82E16813157497 is often recommended.
I have been very impressed with the preempt-rt latency of one of these I just bought
www.ebay.co.uk/itm/RM-19-ALL-IN-ONE-COMP...ows-10-/182802217707
But not knowing where you are in the world it is hard to know if that is any use to you (and fixed monitor means no touch-screen)
21 Oct 2017 03:33 #100603
by JC10
Replied by JC10 on topic End 2017 PC Build for 7I77 retrofit : which motherboard, cpu, video card ?
Hello Andy,
thank you for your inputs.
In between, i found on a Tormach forum that the Gigabyte GAH81M-SP2H motherboard was giving good results wih PathPilot that is running with a touchscreen. So I ordered one refurbished from amazon.com. Will see when I test it. If it turns bad I will get the one you recommend.
Your all in one is a great bargain and I am on the other side of the channel
