Gigabyte n3050N-D2p problem with stability
17 Nov 2017 08:40 #101918
by aleksamc
Gigabyte n3050N-D2p problem with stability was created by aleksamc
Hi all. I've bought mother board with preinstalled cpu Gigabyte n3050N-D2p in mini-itx box with 12V power supply.
Ive installed linuxCNC 2.7.11 with linux debian from linuxcnc.org but this computer works wery unstable.
It could halts after 10 min of work. The temperatore is normal 46 *C on cores.
On the official cite there no any drivers for linux.
What could be problem in?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
17 Nov 2017 10:39 #101922
by InMyDarkestHour
Replied by InMyDarkestHour on topic Gigabyte n3050N-D2p problem with stability
Have you, or are you able to, try a different power supply.
Is the halting the only evidence of instability or are there other things that are showing up.
Have you seen this thread, someone mentioned the routing of the 12V over the RAM was an issue. Is the RAM you are using on the QVL list ? Seems this setup maybe a bit picky about RAM.
20 Nov 2017 08:05 #102051
by aleksamc
Replied by aleksamc on topic Gigabyte n3050N-D2p problem with stability
The problem was solved. I've tried to changes different supplys but problem was in ROM memory. After changing it computer achived stability and good work.
Time to create page: 0.162 seconds
