Preemptive RT on Jessie or Stretch?
26 May 2018 20:45 #111167
by bymccoy
Replied by bymccoy on topic Preemptive RT on Jessie or Stretch?
I have a 2nd embedded IPC on the way, so I’ll try Stretch when I get it. Even with the graphics issues, I don’t dare update the other IPC, as it’s in stable production and working perfectly (minus the missing HD graphics and touchscreen driver).
- InMyDarkestHour
- User is blocked
- Thank you received: 111
27 May 2018 01:28 #111176
by InMyDarkestHour
Replied by InMyDarkestHour on topic Preemptive RT on Jessie or Stretch?
If you are not stuck on a debian based distro, I have found Linuxcnc very easy to install on Salix-14.2 (slackware based so you know it's stable, not bleeding edge). It comes out very light weight and not a lot of excess stuff involved.
HOWTO starts here:
forum.linuxcnc.org/9-installing-linuxcnc...?limitstart=0#110708
HOWTO starts here:
28 May 2018 21:51 #111239
by tlightus
Replied by tlightus on topic Preemptive RT on Jessie or Stretch?
I recently installed 4.16.8 on Stretch using this script file: paste.debian.net/1026684/
Turns out on a J1900 it's much worse than the 4.9 preempt packaged with stretch, YMMV.
06 Jul 2018 22:40 #113612
by bymccoy
Have the IPC, and will be installing OS and LinuxCNC this coming week.
So, since last asking in May, has anybody else gotten Jessie/Stretch working?
Hoping to go vanilla with the Debian install, to make ongoing management and updating easier. As mentioned, need Jessie or Stretch as the HDMI graphics drivers (can’t recall chipset but newer than Wheezy) don’t work (can’t detect the display or map the correct screen size/resolution). I can get the touchscreen working, but it of course doesn’t map with the GUI, and the desktop even scrolls when you go toward the bottom or sides! Really need Jessie or higher on the hardware.
- InMyDarkestHour
- User is blocked
06 Jul 2018 22:59 #113613
by InMyDarkestHour
The following user(s) said Thank You: bymccoy
07 Jul 2018 02:25 #113625
by tlightus
- InMyDarkestHour
- User is blocked
07 Jul 2018 03:13 #113627
by InMyDarkestHour
Yeah that's an abridged version of the one I linked to.
Thanks to JT here's an alternate method to get preempt rt on stretch
paste.ubuntu.com/p/jvDN76Pq7Z/
- InMyDarkestHour
- User is blocked
07 Jul 2018 03:24 #113629
by InMyDarkestHour
If you aren't averse to Linux Mint, the following link has some info on installing LCNC uspace on Mint-18.3
forum.linuxcnc.org/18-computer/34823-a-f...d-up?start=30#113557
A few posts down is a link to my google drive with the kernel & uspace packages.
forum.linuxcnc.org/18-computer/34823-a-f...d-up?start=30#113597
07 Jul 2018 09:08 #113651
by bymccoy
That’s great, thanks.
I think the last I’d read earlier this year, there was no RT compiled kernel, and there were issues with the code base, hence sticking with Wheezy. But looks like the RT kernel is now back...
Will give it a shot and see how I get on. I was genuinely expecting a lot of screwing about to get it installed, rather than just installing the RT kernel and the uspace
- InMyDarkestHour
- User is blocked
07 Jul 2018 09:59 - 07 Jul 2018 14:32 #113653
by InMyDarkestHour
I an hour & half to 2 hours I'll have finished uploading a remastered Linux Mint iso with PREEMPT kernel and linuxcnc pre-installed.
If you are interested send me a message and I can give you the link.
Note that is a neither an official Mint or Linuxcnc distro.
SHARING HAS BEEN REMOVED, FILES ARE NO LONGER AVAILABLE
Last edit: 07 Jul 2018 14:32 by InMyDarkestHour.
Time to create page: 0.161 seconds
