Parport Base Adress Intel Atom 330, 1.6 GHz, ASRock A330GC
- Hujtebesuka
22 Mar 2018 00:48 #107705
by Hujtebesuka
Just got myself Intel Atom 330, 1.6 GHz, ASRock A330GC bundle nice cheap good base jitter
Had issue that
lspci -v
Gives me wrong parport ids
I tryed them all none works
Than look in forum goid job someone sayed to try
0x378 Parport Base Adress
So i resset bios to default put that 0x378 id
And magick its works
Can enyone explain why its like that and how to get right id for parport every time is there any other commands
Many thanks LiveCd 2.7 worked and installed offline, updated using wifi usb card.
Had issue that
lspci -v
22 Mar 2018 00:56 #107706
Replied by PCW on topic Parport Base Adress Intel Atom 330, 1.6 GHz, ASRock A330GC
Motherboard parallel ports are almost never PCI devices
one option for finding addresses is:
dmesg | grep parport
or if you know you have a single parallel port just use a port address of 0
(which means the first parallel port found)
The following user(s) said Thank You: Hujtebesuka
Time to create page: 0.090 seconds
